jeep tj, with yj style roll bar? - JeepForum.com
post #1 of 15 Old 08-31-2012, 11:00 AM Thread Starter
coombie
yep you herd be, i did it, and it was pretty easy, looks good, and once i get padding made it will look like it never happend :P
pipe size is 2 1/4", same as stock roll bar, used 1/2" pipe to build my soft top rear bow. welded it all togeather with mig.
tell me what you think!
chrome dont get you home, guts, rugged jeep guts get you home
coombie is offline
post #2 of 15 Old 08-31-2012, 11:15 AM
bdmead01
Looks great, but I would take the rear seat out now that they have even less roll bar protection.
'00 RED Sport: 4.0L, 32rh, 3.07's and 31's
bdmead01 is offline
post #3 of 15 Old 08-31-2012, 11:32 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I can see doing that for a TJ whose rear seat has been removed and will never have passengers in back. It does bring back a classic look. But to do it strictly for looks since your back seat is still in place, I just can't see taking the chance at the expense of anyone who ever sits in the back seat. Personally, after that rollbar modification that removes all the protection for rear seat passengers, I would permanently remove the back seat and make it impossible to ever reinstall it. Installing something a big tool box in its place will make it easier to not be tempted to ever carry anyone in the backseat again.
Jerry Bransford is online now
post #4 of 15 Old 08-31-2012, 12:15 PM
88hatchy
Is that exhaust pipe?
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #5 of 15 Old 08-31-2012, 12:22 PM
brplatz
X2 on rear seat removal, especially after reading so much discussion on proper cage building.
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #6 of 15 Old 08-31-2012, 02:22 PM Thread Starter
coombie
lol, no, its some old strustural tubing i found around my shop. not sure what gauge but it was heavy as hell. as thick if not thicker than stock. and to everyone elsethe back seat will be coming out perminantly. as for right now there are no belts back there so no one is allowed in the back while the jeep is moving
coombie is offline
post #7 of 15 Old 08-31-2012, 04:20 PM
cheapjeep06
Do you have a close-up pic of the weld to the factory bar? It appears you have squeezed the pipe flat, then cut it at an angle.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #8 of 15 Old 08-31-2012, 05:30 PM Thread Starter
coombie
not really, had to push in outside of tubing 1/8" to allow clearance for my soft top framing , had no choice really, you see when my soft top goes up the bar for the soft top needs clearance so it does not cause the framing for the soft top to become crooked. thus i made clearance by pushing in the outer walls of the tubing 1/8",i was doing all of this with a pos welder, with no gas, a angle grinder, a measuring tape and a grease pencil. hopefully in the future i will be able to touch up a few things.
coombie is offline
post #9 of 15 Old 08-31-2012, 05:51 PM
Vinman
Looks good.
It's just as safe for back seat passengers as any CJ-7 or early YJ.
Vince
Vinman is online now
post #10 of 15 Old 08-31-2012, 06:37 PM
cheapjeep06
Vince
Read post above yours. Do you really think it's that safe.
post #11 of 15 Old 08-31-2012, 06:44 PM
RLD831
RLD831's Avatar
Is there a reason to weld the new bars to the outer edge of the roll cage, rather than to where the factory bars attach? I'm not criticizing, just wondering, as I like the look of the slanted bars also and I always figured the best place to attach them would be the factory location. That way the base of the bars could be welded to the factory plates on the wheel wells, and the soft top bows could use the factory mounting and the bows would clear the new bars.
RLD831 is offline
post #12 of 15 Old 08-31-2012, 08:01 PM Thread Starter
coombie
well, i welded them there because on the yj style bars thats ware they were. i just like the look. and yes i thought about mounting them to the stock locations but i didnt like the look when i tacked them on. so i went with 2.5" below the stock location
coombie is offline
post #13 of 15 Old 08-31-2012, 09:12 PM
Vinman
Oops, I didn't see that post before I posted, I retract my first post.
Permanantly removing the rear seat is a good idea.
post #14 of 15 Old 08-31-2012, 10:13 PM
joe_jeep
looks cool!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #15 of 15 Old 09-02-2012, 02:09 PM Thread Starter
coombie
thanks! and yes the rear seat is now gone. i am putting a tuff box in the back to store/lock my stuff away in.
coombie is offline
bar , jeep , roll , tj , YJ
family style roll bar? mattott YJ Wrangler Technical Forum 6 02-04-2011 11:41 PM
Family style roll bar YJames90 YJ Wrangler Technical Forum 18 09-07-2007 02:55 PM
Where to get Family Style Roll Bar max3k YJ Wrangler Technical Forum 16 05-25-2005 07:37 AM
CJ style roll bar Jeepzilla YJ Wrangler Technical Forum 2 08-01-2003 10:39 AM
old roll bar style of Yj's on newer style? Jeepology YJ Wrangler Technical Forum 3 05-06-2003 04:58 AM
