Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? - JeepForum.com
post #1 of 13 Old 11-12-2010, 11:43 AM Thread Starter
Travisray91
Hey everyone,
Had my jeep since 98' and been LOVIN it. Only problem is... I got a 4-cyl. Now I know i need to upgrade as my miles are starting to climb. I wanted to Switch my current IL 4cyl to a 6 cyl preferrably a new engine. Anyone know of great sites to by engine replacement kits? i Just want to buy everything i need (including block, mounting brackets, etc...).
If anyone has any feedback i would appreaciate it!
Thanks,
Travis Ray
Travisray91 is offline
post #2 of 13 Old 11-12-2010, 11:48 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you can buy a complete V8 conversion kit from AEV or Burnsville Off-Road I would think. Pretty sure you need to source the engine, tranny and t-case though. If you're going to do it, don't go with a V6, just get it over with and go V8.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 13 Old 11-12-2010, 11:48 AM
scottrx7tt
im sure you already know this, but the 4.0L is an inline 6
scottrx7tt is offline
post #4 of 13 Old 11-12-2010, 12:09 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I agree with Unlimited04, do a V8 swap.
You would probably get tired of the I6 pretty quick.
Wheelin98TJ is offline
post #5 of 13 Old 11-12-2010, 12:39 PM
gensysmike
not to be disagreeable. but i went from a 2.5 to 4.0, and i find the 4.0 to be more than adequate. i am sure the v8's are awesome power wise...but not everyone needs that.
gensysmike is offline
post #6 of 13 Old 11-12-2010, 12:42 PM
Melissas6570
I think if I were going to all that trouble I would do a 318 from a durango or ram.
I DO IT WITH MY TOP OFF!
Melissas6570 is offline
post #7 of 13 Old 11-12-2010, 12:51 PM
theducksguts
If you are going to go through the trouble to source the parts, weld in new mounts, replace the transmission, transfer case (or just the input), and computer plus wiring.
Why wouldn't you just put in a V8? There are plenty of them out there. Are you worried about smog and all that CA inspection stuff? Because I'm pretty sure you are going to need to do the same VIN flashing on the computer as you would with the 4.0L.
Or just do what you want. I don't see the point though.
Check out my
theducksguts is offline
post #8 of 13 Old 08-13-2011, 06:41 PM
SamM
What about using the Jeep Liberty 3.7L V-6? My wife's Liberty has plenty of power. In the lighter TJ platform the 3.7L and a NV3550 5-speed would been a great combination. Add in a Warn lock-in, lock-out hub conversion and it may even get decent fuel economy. The Liberty came with the NV3550 and the engines are cheap to source at local swap yards. Cheap enough that I could have on rebuild and sitting ready to go in the event of an engine failure.
Using a less powerful engine means that I could get away with out doing expensive axle swaps and upgrades just to keep my axles from failing. In the end, I'd probably still buy a Dana 44 for the rear but a high pinion XJ front axle would work in the front. I can get the high pinion D30 for $50.
SamM
SamM is offline
post #9 of 13 Old 08-13-2011, 07:21 PM
rda616
I would go with a 99+ 5.9 out of a ram pickup, or van! Take all the emissions stuff, engine harness, pcm and accessories! You need an engine the same model year or newer to pass smog in ca.
rda616 is offline
post #10 of 13 Old 08-13-2011, 07:27 PM
D0dgeRam1500
Some of the V8's will increase your gas mileage as well as power. The 4.7L Power Tech gets better gas mileage than the 4.0. One of the things I wanted to do to my Cherokee before I got rid of it was to swap in a diesel. Great low end torque and much better gas mileage than a gas motor. Either way is good. As much as the 4.0 is a good motor, I wouldn't bother with it.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #11 of 13 Old 10-04-2011, 04:44 PM
terpsmandan
2009 JK Wrangler
I agree with the others, if you are going to go through all the hassle of swapping out the engine, just go for a GM GenIII small block.
terpsmandan is offline
post #12 of 13 Old 10-04-2011, 08:21 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Check out Advance Adapters and Novak Adapters. They not only sell adapters and such, but are a wealth of conversion information.
http://www.advanceadapters.com/
http://www.novak-adapt.com/
armyRN is offline
post #13 of 13 Old 10-05-2011, 12:50 PM
acrijos
Try Golen engines at http://www.golenengineservice.com/engines/jeep/. You can get a stock 4.0 or a stroked 4.6. They have a lot of experience with jeeps. They also sell turnkey V8 engines.
We don't stop playing because we grow old. We grow old because we stop playing.
acrijos is offline
2004 jeep wrangler se with stock 4.56 gear question. The4Banger TJ Wrangler Technical Forum 27 01-09-2011 05:25 PM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 Jeep Wrangler--stumbling!! Wranglergirl_co TJ Wrangler Technical Forum 3 05-24-2009 03:29 AM
Will a 2006 stock radio from a jeep wrangler fit a 1999 jeep wrangler 1954Dodge TJ Wrangler Technical Forum 2 08-16-2008 09:40 AM
1997 Jeep Wrangler 2.5L 4 cyl... JeepMan905 TJ Wrangler Technical Forum 11 05-31-2007 02:24 PM
