jeep tj tub rot...? - JeepForum.com
post #1 of 11 Old 08-12-2012, 11:27 AM Thread Starter
coombie
jeep tj tub rot...?
hi, i have a 03 tj, 141,000km on her but the tub is starting to rot just below the licence plate.. was wondering if this is a normal tj thing or if i should be looking into this rot further i will end up fixing it but just looking to see what other people have done to either prevent the rot or reverse it
thanks
chrome dont get you home, guts, rugged jeep guts get you home
coombie is offline
post #2 of 11 Old 08-12-2012, 11:33 AM
VT_Rubi
If you look above the gas tank you'll probably find a lot of rot started. The more important thing I would be concerned about is the frame. Check the whole vehice out and grind away what you can, then replace metal if needed and re-paint.
Depending on how nice you want the jeep to be will determine how much time and money you want to invest. Where I live, ALL vehicles that are driven in the winter rust away eventually.
VT_Rubi is offline
post #3 of 11 Old 08-12-2012, 11:42 AM Thread Starter
coombie
the frame is good, the rust it has isnt through the steel, its just on the surface, paint is beginning to bubble. but thanks, i will have a look up there and see
coombie is offline
post #4 of 11 Old 08-12-2012, 11:53 AM
VT_Rubi
I'd say it's normal, but you'll want to take care of it sooner than later.
VT_Rubi is offline
post #5 of 11 Old 08-12-2012, 12:00 PM Thread Starter
coombie
yea, planning on wire wheeling that corner, epoxy'ing it and getting it professionally pained if i dont have to cut the steel out.....
coombie is offline
post #6 of 11 Old 08-12-2012, 12:07 PM
MattJeep
2003 WJ
You'd have to cut that steel out to really stop it. Its way too late. Best thing is to take a grinder and wire wheel and remove as much as possible. Then smooth it with some bondo, then paint. I had to do both sides on mine. Still looks pretty good.
MattJeep is offline
post #7 of 11 Old 08-18-2012, 09:01 PM Thread Starter
coombie
well ive repaired, it. had to cut out the rot but in the end it looks good not perfect, but a hell of alot better
coombie is offline
post #8 of 11 Old 08-18-2012, 10:32 PM
88hatchy
What kind of paint did you use?
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #9 of 11 Old 08-18-2012, 11:04 PM
MattJeep
2003 WJ
Great job. Amazing what you can do in an afternoon. Bondo does a great job when used correctly.
MattJeep is offline
post #10 of 11 Old 08-19-2012, 04:08 PM Thread Starter
coombie
well i used chrystler paint code reproduction paint. cant tell the diffrence between the panals :P got it at canadian tire but im sure you can buy it from any auto parts store
coombie is offline
post #11 of 11 Old 08-19-2012, 04:09 PM Thread Starter
coombie
thankyou, and yes bondo does
coombie is offline
jeep , rot , rust , tj , tub
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 01:50 PM
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 10:31 AM
Got jeep back from shop, coolant level low, jeep running cold. kainers YJ Wrangler Technical Forum 4 10-30-2010 08:51 PM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 10:26 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 05:46 PM
