-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   jeep tj tub rot...? (http://www.jeepforum.com/forum/f9/jeep-tj-tub-rot-1404422/)
coombie 08-12-2012 11:27 AM
jeep tj tub rot...?
hi, i have a 03 tj, 141,000km on her but the tub is starting to rot just below the licence plate.. was wondering if this is a normal tj thing or if i should be looking into this rot further :( i will end up fixing it but just looking to see what other people have done to either prevent the rot or reverse it
thanks
VT_Rubi 08-12-2012 11:33 AM
If you look above the gas tank you'll probably find a lot of rot started. The more important thing I would be concerned about is the frame. Check the whole vehice out and grind away what you can, then replace metal if needed and re-paint.
Depending on how nice you want the jeep to be will determine how much time and money you want to invest. Where I live, ALL vehicles that are driven in the winter rust away eventually.
coombie 08-12-2012 11:42 AM
1 Attachment(s)
the frame is good, the rust it has isnt through the steel, its just on the surface, paint is beginning to bubble. but thanks, i will have a look up there and see
VT_Rubi 08-12-2012 11:53 AM
I'd say it's normal, but you'll want to take care of it sooner than later.
coombie 08-12-2012 12:00 PM
yea, planning on wire wheeling that corner, epoxy'ing it and getting it professionally pained if i dont have to cut the steel out.....
MattJeep 08-12-2012 12:07 PM
You'd have to cut that steel out to really stop it. Its way too late. Best thing is to take a grinder and wire wheel and remove as much as possible. Then smooth it with some bondo, then paint. I had to do both sides on mine. Still looks pretty good.
coombie 08-18-2012 09:01 PM
6 Attachment(s)
well ive repaired, it. had to cut out the rot :mad: but in the end it looks good :) not perfect, but a hell of alot better
88hatchy 08-18-2012 10:32 PM
What kind of paint did you use?
MattJeep 08-18-2012 11:04 PM
Great job. Amazing what you can do in an afternoon. Bondo does a great job when used correctly.
coombie 08-19-2012 04:08 PM
well i used chrystler paint code reproduction paint. cant tell the diffrence between the panals :P got it at canadian tire but im sure you can buy it from any auto parts store
coombie 08-19-2012 04:09 PM
thankyou, and yes bondo does :)
The time now is 06:21 PM.
