Jeep Tj Supercharger - JeepForum.com
 1Likes
post #1 of 45 Old 08-14-2003, 03:57 PM Thread Starter
KEATSKI
Have a "97" with the 4.0 liter engine. Have any of you put on a Supercharger or Turbo on this engine. Saw an article in a magazine and couldn't reach the manufacturer. Any thought on it? What is the cost, can do yourself and is it worth it?
KEATSKI is offline
post #2 of 45 Old 08-14-2003, 04:05 PM
ace2222
Is it worth it depends .. I have been looking in to the avenger system!!!! I don't know if you can install it yourself and I think I was given a price of 3300 for the avenger
ace2222 is offline
post #3 of 45 Old 08-14-2003, 04:27 PM
BearClaw
If you just off road, you don't need any of that. A nice set of gears will give you all the power you'll need.
If you want to embarrass some fixed up import or whatever you might have next to you under a red light... here are some available for a TJ
http://www.off-road.com/jeep/reviews...rxengineering/
http://www.4x4wire.com/jeep/news/avenger01/
http://www.vincihiperformance.com/SUVMAINPAGE.HTML
just few...I'm sure you'll find more with if you just do a search for it.
I'm thinking about the first one, factor x engineering
BearClaw is offline
post #4 of 45 Old 08-14-2003, 05:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For that kind of money, I'd go for a nice Chevy V8 350 any day.
Jerry Bransford is offline
post #5 of 45 Old 08-15-2003, 06:56 AM
GoTopless
GoTopless's Avatar
why would you want to do that? Jeeps are not made for speed......look at it, its a big box! Get a honda
GoTopless is offline
post #6 of 45 Old 08-15-2003, 07:23 AM
kdavis
kdavis's Avatar
Agree with Jerry...if you're going to drop that kind of coin, and you're trying to get raw power, you'd be better off with a crate motor 350 from Summit or something. It's probably more work, but the 350 is the has more parts available for juicing it up than any other motor out there, and it's a great motor.
I also agree, though, it's a waste of money, imho, just seems like you're trying to get your TJ to do something it wasn't meant to...buy an old Chevelle, Nova, or something like that for going fast....
Or, come by, drive my 2.5L for a week and then you'll feel better about your 4.0L.
<>< KD ><>
2004 TJ Wrangler Rubicon (Sugar High)
kdavis is offline
post #7 of 45 Old 08-15-2003, 07:26 AM
GoTopless
GoTopless's Avatar
<dreams of owning a nova or chevelle>
post #8 of 45 Old 08-15-2003, 07:33 AM
kdavis
kdavis's Avatar
I've had 2 1967 Chevelle's that I did frame-offs on...did the same motor set up on both...350ci, ~375HP....ahhhh, I can still see the "chirp" marks from the shift points down my little street....
<wake up>
I'm old, I guess, the 4cyc does it just fine for me now....
<>< KD ><>
kdavis is offline
post #9 of 45 Old 08-15-2003, 08:17 AM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
*This just in*
Hondas are not fast.
I sold my 12 sec. camaro to pay for my lift and tires and such. I miss the power of that car... it was getting close to 400 lbs of torque.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #10 of 45 Old 08-15-2003, 08:23 AM
GoTopless
GoTopless's Avatar
Originally Posted by SlinkyTJ
*This just in*
i wouldnt know......im not into the ricers, everyone one around here seems to think they are fast
post #11 of 45 Old 08-15-2003, 08:45 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Unless you are planning on drag racing, I wouldn't get a centrifugal type blower. A roots blower offers more of the type of power you would need, full boost at a low RPM and a flat torque curve all the way across the entire RPM range. This would make it alot easier to turn those bigger tires.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #12 of 45 Old 08-15-2003, 09:19 AM
AggieTJ
Let me throw in my two cents:
A supercharger is something I wouldn't disagree with. With bigger tires, you'll lose highway passing power. There are some SLOW people out there who don't move over and hold up traffic. If your power suffers enough with the addition of bigger tires, it might be helpful to install a supercharger for those blasts past slow-folks and 18-wheelers.
I'd like to have my Jeep drivable to the trail, and not just a trailer rig, so extra power is something I'll consider in the future when I lift my rig. In stock form, the Wrangler has some nice get up and go. A better exhaust might help a little as well.
Don't laugh, but has anyone ever considered a nitrous system for those quick highway blasts?
'03 Wrangler Sport
RE 3.5" lift, RE front adjustable track bar, OME Nitrocharger shocks and SS, Cragar steels, BFG 33x12.50 Mud-Terrains. LoD rear bumper and tire carrier, Bestop Bikini top.
AggieTJ is offline
post #13 of 45 Old 08-15-2003, 09:23 AM
igofshn
Locked @ both ends
igofshn's Avatar
Let's see, Supercharger = $4000. Gears = $1200. You can do the same thing with new gears. I'd do gears instead.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #14 of 45 Old 08-15-2003, 09:29 AM
ian-X
ian-X's Avatar
I disagree with jerry on this. one of the major advantages of running a centrifugal blower is that you can drive your vehicle normally all day long without using much boost, but when you do need it it'll be there. unlike a 350, it's going to be a gas hog no matter what, with your 4.0L low RPM's will keep that in check. so if you decide to tow, or need more power crawling in 4-low, you put it in a lower gear and get a dramatic torque boost.
also, another major concern is weight. a 350 weighs more so the swap out will not only be the actual fitment of the motor but a replacement of your front springs(maybe just a spacer).
and as Owen says, what good what a thread be with some pictures. this is what I was running on my 5.9L dakota before I sold it. stock the motor was 255hp(crank), with the blower it was 350hp(crank). after a few more mods and the blower is dyno'd 350 at the rear wheels.
If what i said can be taken two ways, then i meant it in the good way.
ian-X is offline
post #15 of 45 Old 08-15-2003, 09:49 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Would that be a Powerdyne SC ian-X?
Devious is offline
Supercharger RRCP08JK JK Wrangler Technical Forum 2 06-18-2009 03:40 AM
3.8 Supercharger Kit 07 jeep thundercat900 JK Wrangler Technical Forum 48 02-28-2007 05:50 PM
Supercharger iamabert TJ Wrangler Technical Forum 2 07-17-2006 06:13 AM
jeep supercharger Lyle36 YJ Wrangler Technical Forum 1 06-03-2002 08:05 PM
