Jeep TJ Spark Plug Reccomendations - JeepForum.com
 1Likes
post #1 of 76 Old 04-08-2011, 09:53 PM Thread Starter
evan1395
Ive read around on this forum and gotten TONS of different opinions on the exact type of spark plug to use in the TJ's. So far the Champion Spark Plugs seem to be the way to go for the Inline 6's. However some people swear by the E3 diamond fire spark plugs also. In the everyday Jeep owners opinion what do YOU personally reccomend for the Straight 6's. Also, the gapping is .35" correct, and they do come pre-gapped right?
Thanks,
Evan
evan1395 is offline
post #2 of 76 Old 04-08-2011, 09:59 PM
TJJP77
TJJP77's Avatar
This engine responds well to either standard copper/nickel plugs, or single electrode double platinum plugs, such as the autolites or champions. Chrysler switched from Champion plugs to NGK towards the end to improve cold start characteristics as well as hot restart issues, so you may want to consider the NGKs as well. I personally wouldn't waste my money on these "E3" plugs.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #3 of 76 Old 04-08-2011, 10:20 PM
parcours
Champions here... They work great!
parcours is offline
post #4 of 76 Old 04-08-2011, 10:37 PM
sxysouthtx
X2 on the crap "E3's".
I personally like to call for the OEM specs. I go close as possible with autolites. I got the coppers and gaped them to .035" and she runs perfect. Don't mess with a good thing. And don't run too cold of a plug, that's just trouble,
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #5 of 76 Old 04-08-2011, 10:41 PM
Benderff
Benderff's Avatar
I'm sure a new thread about the same old question will solve it for everyone....
Thanks,
Evan
Benderff is offline
post #6 of 76 Old 04-08-2011, 11:22 PM
Best4x4
Champion 7034's
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #7 of 76 Old 04-08-2011, 11:28 PM
NCUNLIMITED
I did a poll on this same subject and went with the Autolite app985's and they were a huge difference. The Champion 7034's are good too but I couldn't find them anywhere.
http://www.jeepforum.com/forum/f9/re...-plug-1134593/
NCUNLIMITED is offline
post #8 of 76 Old 04-09-2011, 12:05 AM
RogueSpear2023
I run Autolite APP985 double platinum plugs, also the Champion 7034 double platinums work well too. Those are the only ones other than standard copper that will work, everything else you will have issues with trust me it's been tried. The waste spark system in the wrangler while extremely reliable is very picky about the plugs you use.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #9 of 76 Old 04-09-2011, 06:52 AM
BC Jeep
If I had a choice between Champion and AUTOLITE,,,,,,,, AUTOLITE would win 100% of the time and I'm not even a FORD fan! I HATE Champion plugs! Had a significant issue with them once. In my opinion, there junk!
I'm sure that there are better quality than they were years back but,,, I will not use them.
Another great LONG LASTING Spark-plug is the AC Delco Iridium plugs. I own C5 and C6 Corvettes. They use the AC Delco Iridium plugs and they perform FANTASTIC..
Iridium doesn't PREFORM any better than any other spark plug. They just last a LOT LONGER and hold their set gap better! The best performing Spark-plug is a Copper Core Plug but,, they DO NOT last as long as a rare metal plug.
Fancy high dollar Spark-plugs don't make HP. Plugs with MULTIPLE gaps look cool but, the spark only jumps from ONE GAP at a time!!!
Spark plug wires are the same. FANCY $200 wires will NOT increase HP.. There are basically THREE types of spark plug wires used on modern engines.
Solid Core ( Not recommend,, but for all out racing applications)
Suppressive Carbon Core: (Inexpensive wires used on common platforms. High Resistance wires! )
Inductive Spiral Wound Core wires. They use Nickel Alloy Wire for the conductor that is spiral wound around a nylon or amrid core. One of the best wires made and has the lowest resistance for a stock wire. A good spiral wound wire cant be beat for performance and longevity.
There are other types of wires and most of them are hype. Stick with the spiral wound core wires with good quality silicone jackets and boots.
BC
BC Jeep is offline
post #10 of 76 Old 04-09-2011, 07:17 AM
wheels082
2010 JK Wrangler
I like the Champion plugs in my straight 6. I would not recommend the E3 plugs.
wheels082 is offline
post #11 of 76 Old 04-09-2011, 07:54 AM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
Autolite APP985 plugs for 2000-2006'.
TheBoogieman is offline
post #12 of 76 Old 04-09-2011, 08:05 AM
joe_jeep
what is the reccomended change interval for plugs in the new c.o.p. 4.0L's?
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #13 of 76 Old 04-09-2011, 08:08 AM
joe_jeep
Thanks,
Evan
never trust the factory pre set gap on a plug. they get bounced around in shipment too much. what if your local parts monkey drops them?
its important you check your gaps!
brand and style is up to you. id use the factory champion or the autolite myself. i have had good luck with ngk also. they are all quality plugs and should perform well. the fancy multi-tip plugs are a waste of money.
glfwda #6624
joe_jeep is offline
post #14 of 76 Old 04-09-2011, 08:19 AM
TheBoogieman
Dead Jeepers Club
The APP985 plugs will last 100,000 miles.I change the stock plugs at 50,000.
post #15 of 76 Old 04-09-2011, 09:12 AM
TJJP77
TJJP77's Avatar
Not to derail the thread, but Ford hasn't owned Autolite for a long time - they were forced to sell the brand in around 1972-1973 for anti-trust reasons. Ford then re-launched the Motorcraft brand (they had used the name unsucessfully in the '50's) to replace it, which it still owns today.
Chris
'02 Sahara
TJJP77 is offline
Spark Plug Help captjanes TJ Wrangler Technical Forum 16 02-11-2011 06:48 PM
What spark plug for 2004 Jeep TJ, stock. amike_321 TJ Wrangler Technical Forum 25 11-16-2009 02:52 PM
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
Yet Another Spark Plug ? fundabug TJ Wrangler Technical Forum 5 03-23-2006 07:12 PM
spark plug gap? mcbuck TJ Wrangler Technical Forum 4 02-08-2005 12:29 AM
