Jeep TJ making whining noise from rear end. - JeepForum.com
post #1 of 5 Old 07-07-2012, 11:05 PM Thread Starter
Davetha
Davetha's Avatar
Hey guys,
So after a wheeling trip I noticed on the way back that my Jeep started making kind of a whining noise from the rear end. It sounded like it was coming from the passenger side, but it could be coming from else where.
I took off the passenger side wheel, and inspected the brakes, just incase there was something that might have been stuck in the drum, but didn't find anything.
I've uploaded two videos, and was wondering if any of you think you could pin point what it is from the sound. I drained the gear oil and checked out the diff as well. I'm didn't see anything out of the ordinary, however I'm no pro!
The sound seems to start at around 37mph, and gets a lot louder at around 42mph~
Video 1
Video 2
Davetha is offline
post #2 of 5 Old 07-09-2012, 08:37 PM
Rilles1
Does it make it when you let off primarily? because if so mine does the same..exhaust my friend
Rilles1 is offline
post #3 of 5 Old 07-09-2012, 08:49 PM
saharacon87
Thats def from your rear end. Sounds like you messed up your bearings.
TJ 3" FT, Front Currie Arms, v8 zj steering, 30 locked/44 open, 33 m/t, Armor
saharacon87 is offline
post #4 of 5 Old 07-09-2012, 10:48 PM
LRod
What's the light that comes on at the right hand upper corner of the dash? Is it a locker light or ck engine light?
LRod is offline
post #5 of 5 Old 12-02-2014, 05:59 AM
atc5011
I know this is a very old post, but is the exact same noice i am experiencing on my 99 tj.. any solutions? Ive read from bearings to entire rear differential replacements!!
atc5011 is offline
Jeep Whining/Whistling Noise RobSheaTJ TJ Wrangler Technical Forum 1 10-31-2011 04:04 PM
Whining Noise in Jeep TJ 2006 Brodious TJ Wrangler Technical Forum 1 10-10-2011 03:18 PM
Distributor making whining noise when cold Ragtops TJ Wrangler Technical Forum 4 01-06-2009 10:37 AM
Distributor making whining noise jeepuga TJ Wrangler Technical Forum 4 11-02-2008 01:17 PM
jeep making whining sound while driving jkenn72 TJ Wrangler Technical Forum 1 10-10-2007 09:26 PM
