jeep tj led hood light bar mount - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > jeep tj led hood light bar mount
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 02-27-2014, 06:55 AM   #1
CPFLIP
anyone know of an idea to mount a rigid industries light bar on the hood of the jeep tj? ik they make one for a jk but cant find anything for a tj
CPFLIP is offline   Reply With Quote Quick reply to this message
Unread 02-27-2014, 07:09 AM   #2
rgvjeep
check undercoverfab,
rgvjeep is offline   Reply With Quote Quick reply to this message
Unread 02-27-2014, 08:37 AM   #3
Platypus
Built In The Rain
Platypus's Avatar
I've also been looking into modifying the Jk one. Does anyone know the difference between a TJ and Jk hood hinge?
Sent for me by R2-D2
/l ¨¨◘[____]◘ ¨¨
l---L—OlllllllO-
()_) ()_)-Θ-)_)
Platypus is offline   Reply With Quote Quick reply to this message
Unread 02-27-2014, 09:39 AM   #4
charlie101
This is the UCF bracket
charlie101 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 07:26 AM   #5
CPFLIP
im interested in that too what would be the difference between the jk and tj hinges on the hood
Unread 02-28-2014, 07:41 AM   #6
fsumatt12
Made my own, worked out nice! You will have to zoom in on the photo to see it, can post better pic later.
fsumatt12 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 08:11 AM   #7
kajones
Motobilt also makes ones that mounts to the hood hinges.
http://www.motobilt.com/lighting/jee...mount-kit.html
kajones is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 05:39 PM   #8
Carlos14
Afraid of the Dark
Carlos14's Avatar
X2 on Motobilt. He makes good stuff.
Teenager With A Dream Build
I think you're skewing the facts. Clarity is relative. Our job is to lead people to the kingdom of heaven, not make them think they're looking at it. :D
Poison Spyder Hood Louver Install
Carlos14 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 09:26 PM   #9
TXST8tj
Motobilt
TXST8tj is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 09:32 PM   #10
frenchy206
Originally Posted by TXST8tj View Post
Motobilt
Do you get a lot of hood glare?
03 TJ Rubicon
frenchy206 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 12:47 PM   #11
cmecha
are the windshield washer nozzels effected? and how did you run the wiring
"always upgraded, never replaced."
cmecha is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 02:04 PM   #12
Xtremegameroom
With my highlift jack mounted on the hood in that spot thats much higher than that light the washer nozzles are affected, so yes with that light they are affected
Xtremegameroom is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 05:28 PM   #13
TXST8tj
Nothing that is blinding to the driver, or obnoxious.
The nozzles are affected a little. The fluid still sprays the windshield, just some of it hits the bottom of the lightbar. If you had a single row light bar with a shorter housing, it would not hit.
An ever-so slight increase in the height of the mounts would solve the issue all together. I have talked to Dan about this.
Unread 10-18-2014, 08:49 AM   #14
BigOleTJ
im curious as to how you wired it. did you drill a hole through your hood or what?
BigOleTJ is offline   Reply With Quote Quick reply to this message
