Jeep Tj Engine Hesitation/ Low Oil Pressure - JeepForum.com
post #1 of 1 Old 07-06-2011, 05:42 PM Thread Starter
Phillip0909
Hi all, I am experiencing some engine problems with my 97 Tj 4 cyl 5 speed with 113k. Some background information, I have recently put a new cat on it with new o2s, a new TPS sensor, and I just cleaned the throttle body and ITPS sensor. The problem is after start up immediately when I go into first or reverse as soon as my foot comes off the gas the engine goes to almost 0 rpms and almost stalls. But after warming up it doesn't act up as much. After the engine gets warm while I'm sitting at a stop sign or red light it will almost stall as well. In accordance with that my oil pressure gauge drops to almost zero psi and remains very low or at zero after I have been driving for a while. Are these problems related? I think the oil pressure problem is a sensor because I'm not hearing any strange noises when the oil pressure goes down. Is it a fuel pump or oil pump? The symptoms I described are sparatic as well. Some days it will run better than others. Thanks for the help. FYI my computer isn't giving any codes. Thanks, Phillip
Phillip0909 is offline
engine , idle , low , oil , pressure
2.5L engine hesitation after start up the_art_of_desi TJ Wrangler Technical Forum 5 07-08-2009 05:24 AM
2.5 engine hesitation ffmed1212 TJ Wrangler Technical Forum 1 08-02-2008 07:14 PM
Engine hesitation? thenewkid TJ Wrangler Technical Forum 9 07-17-2006 12:05 PM
4.0 Engine Hesitation - Please Help! Tred TJ Wrangler Technical Forum 5 05-12-2006 08:39 AM
engine hesitation Benson84 YJ Wrangler Technical Forum 2 10-16-2002 12:37 AM
