Jeep TJ 4 cylinder Engine noise - JeepForum.com
post #1 of 8 Old 04-12-2012, 12:41 PM Thread Starter
wellsb1
Hello everyone. This one has me perplexed so I am hoping for some extra help
I have a 1997 TJ with the 2.5 4 cylinder, automatic. The Jeep runs great, no engine codes, but when the engine warms up, it sounds like a diesel engine and I cannot pipoint the source. Not the exhaust, not the catalytic converter, oil pressure is good, pulleys are all tight, water pump is new. Help!
wellsb1 is offline
post #2 of 8 Old 04-12-2012, 01:16 PM
Line58
In other words, it sounds like a 16 year old 2.5L? Mine and many others sound the same. If you can find a cure to make it sound new again please let us know, however that unhealthy sound seems rather common.
Line58 is offline
post #3 of 8 Old 04-12-2012, 01:35 PM
todd8888
Mine has 140,000 and does the same thing. Sounded like it was in the top so i changed the lifters (found 3 of them colapsed), but still makes the same noise after running about 5-10 minutes. If you find the cause let us know.
Mine also uses no oil, runs smooth, just sounds like a diesel.
todd8888 is offline
post #4 of 8 Old 04-13-2012, 05:13 AM Thread Starter
wellsb1
Thanks foir the replies. That makes me feel a lot better as it does not sound good, but performs flawlessly.
Happy Jeeping everyone!
wellsb1 is offline
post #5 of 8 Old 04-13-2012, 07:15 AM
tjsooner
Mine had ticked for the 3 years I've had it. This Monday the ticking got much, much louder and the Jeep is in the shop now. Might need a rebuild or a new engine. Not sure what went but something bad happened. Never ran bad or overheated even once the loud ticking started.
tjsooner is offline
post #6 of 8 Old 04-13-2012, 02:08 PM
Dextreme
A $5 Mechanics Stethoscope can help isolote the problem, especially if it is an exhaust manifold leak.
http://www.harborfreight.com/mechani...ope-41966.html
'99 Chilli Pepper TJ Wrangler -- "Mistress"
Zone 4.25"
33" GY Duratrac's
Dextreme is offline
post #7 of 8 Old 04-13-2012, 09:31 PM
Rio_Grande
Exaust manifold leaks are really common in these units. The back lower bolt often breaks off in the head.
I love this crap!!
Rio_Grande is offline
post #8 of 8 Old 04-13-2012, 10:37 PM
BucketOKarma
Mine had a similar problem, found two separate places. One, my air intake was whistling, and second, the donut gasket between the manifold and down-pipe, was shot.
Now it sounds fine.
I hope that helps at least someone here....
... Although, I do have a ticking (like the "60 minutes" stopwatch), it's most prominent when in third gear under load (like getting on an on-ramp). It has me worried, but not enough to take it apart and possibly do more harm than good, or have someone else take it apart and have it do more harm to my wallet.
2000 2.5L 5spd 4.88, HP D30 w/OX, D35 open, 3" "FrAnKeNLiFt" with some stuff... LOOKING FOR Willys Edition TJ rear seat! to match the fronts.
BucketOKarma is offline
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
4 Cylinder engine noise flyin-lowe TJ Wrangler Technical Forum 8 02-07-2010 09:49 AM
pulling my cylinder heads off, and possibly diagnosing my engine noise yj_beater51 YJ Wrangler Technical Forum 25 12-28-2009 04:34 AM
Jeep Engine Tapping Noise = broken Jeep Engine McLeod TJ Wrangler Technical Forum 14 01-14-2007 09:38 PM
can Jeep make a 5 cylinder engine? losfreddy TJ Wrangler Technical Forum 21 02-17-2006 08:08 AM
