Jeep Tj 4.0 Turbo Charger - Page 2 - JeepForum.com
post #16 of 209 Old 09-08-2008, 01:10 PM
-Rudy-
2003 WJ
Originally Posted by COBY View Post
a good turbo setup will do nothing but help your top end! you got to set it up correctly throw so i would look for a kit with all the math done already. and as for durability my last 2 trucks (18 wheelers) had 500,000 miles on them and the turbos never gave me a single problem just don't run in deep water after running the engine hard.
Your last 2 trucks had humongous diesel engines capable of boost pressures that gasoline powered cars could only dream of. Let's not compare the two.
2003 WJ Laredo 4.0/242: 3" IRO, Bilstein 5125, Supporting Mods
2004 WJ Limited 4.7/247/QD
-Rudy- is offline
post #17 of 209 Old 09-08-2008, 01:14 PM
COBY
COBY is offline
post #18 of 209 Old 09-08-2008, 01:18 PM
COBY
the turbo is the same just smaller and the jeep 4.0 has 8.5 to 1 com. you cant get much lower then that! trucks don't run big boost that is a rice racer thing man.
COBY is offline
post #19 of 209 Old 09-08-2008, 01:22 PM
-Rudy-
2003 WJ
A) It's a magazine article.
B) I see no dyno sheets that provide a consensus of where and when the power came on.
C) They gained 65 HP to the wheels on a manual tranny. Autos have more drive-train loss. So, the power gains are even worse than I expected to see.
D) I see the word "Theory" and other versions of it being tossed around a lot.
-Rudy- is offline
post #20 of 209 Old 09-08-2008, 01:27 PM
-Rudy-
2003 WJ
Do you have any idea how much boost a stock cummins diesel in a dodge runs? Our stock '02 6-speed pumps out 26 PSI... with no mods. The Jeep in your link was only running 6.5. 20 PSI is a huge difference. There is an even bigger difference in a big-rig's systems.
Do you realize that the fuel and exhaust burning properties of your rigs and a gasoline powered Jeep TJ are 2 entirely different things?
-Rudy- is offline
post #21 of 209 Old 09-08-2008, 01:29 PM
COBY
1. 65 hp is nothing to laugh at
2. dont bite my head off im just trying to help
3. do what you want to your jeep i like turbos
COBY is offline
post #22 of 209 Old 09-08-2008, 01:35 PM
-Rudy-
2003 WJ
I'm not biting your head off, I'm trying to show you that a turbo is not very cost effective compared to other things that may improve you performance.
Unless your goal is to have some amazing 100 mph drag-jeep...
-Rudy- is offline
post #23 of 209 Old 09-08-2008, 01:36 PM
COBY
i was saying the turbo will last a long time not to put a unit the size of your head on a stock jeep....dang!
in my first post i told him to get one set up correctly in a kit.
if you do it right it will work right
COBY is offline
post #24 of 209 Old 09-08-2008, 01:38 PM
carpekd
I think if your using your jeep for a trail rig, a setup other than a turbo is what you need. Perhaps a regear and/or stroke? That would be bullet proof and powerful on the trail.
carpekd is offline
post #25 of 209 Old 09-08-2008, 01:40 PM
joeyprice
joeyprice's Avatar
2014 JK Wrangler
Why not go with a good stroker kit?
http://www.fourwheeler.com/techartic...six/index.html
Originally Posted by martinsburgjeep
what can I say, every time I think of you my colon explodes
joeyprice is offline
post #26 of 209 Old 09-08-2008, 01:55 PM
onlyn8v
Originally Posted by litebrite2001 View Post
Exactly. Could you imagine restricting it even further?
You drive on torque, you dont rev a jeep to kingdom come anyway. You could put a a t3 .42 from a Saab on there and get torque really low and who cares if the flow will not be efficient at 7k? The Jeep motor is a torque motor not a motor for revs so my point is top end (revs) are pointless.
Do what you want and think what you want- but every motor can benefit from turbo charging- its all in how you design it
As far as that kit goes above a T3 super 60 is about as old school as one can make a turbo. A 3076R with a .82 turbine would make alot more power and at lower revs.
Dave
1990 VW Corrado Turbo
1998 VW Jetta TDI
1999 VW Jetta TDI 4 SALE!!
onlyn8v is offline
post #27 of 209 Old 09-08-2008, 02:51 PM
litebrite2001
Who said anything about revving to 7k? Redline is 5200, and at 4600, the power is falling off quickly. Putting on a turbo small enough to be spooled off idle will choke it after a few thousand. Obviously, a well sized turbo will minimize this effect. Slight turbo lag, with slight restriction in the top end. I've said it, no less than twice now, that proper sizing is important (or as you say, design). But thanks for re-iterating my point.
That being said, I'm out of this one. I had a 2002 Grand Cherokee with a 4.0 and it had plenty of power for my taste. Same engine in a 1000lb lighter wrangler is more than enough. There's really no reason for me to be in a power thread.
litebrite2001 is offline
post #28 of 209 Old 09-08-2008, 02:57 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
If you actually understand the physics behind turbos, then you'll understand this:
1. turbo lag is dependent on the size of the turbo & exhaust system - turbos are turned by exhaust backpressure...so on a 4.0L the turbo only needs to be active between idle-5,000 rpms, thats a lot different than a race car where you'd want 4,000-9,000 rpms.
2. turbo do not have a parasitic loss like superchargers.
3. boost can be talored to engine components, on the fly with adjustable valves
4. a correctly sized turbo will produce more fluid power and torque than a conventional supercharger. i'm excluding electronically controlled variable pitch turbos, and the fancy electronically controlled mercedes superchargers...just talking basic forced induction here.
505 Performance makes the only commerically available turbo kit for a 4.0L. www.505performance.com
I have ridden in a Rubicon with a 505 Performance kit installed. it was silly fast for a jeep, even kinda scary considering the SWB isnt that stable to begin with. i have driven and ridden in many fast cars, from supercharged mercedes, V8 caddy's, AWD Subi's, Saab's to a WS6 Firebird, so i know what stability at high speed is...and the Jeep doesn't have anything close.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #29 of 209 Old 09-09-2008, 12:40 AM Thread Starter
Grants99TJ
Damn all this and i just wanted a lil more power and the cool ppppfffffshhhhh sound when i shifted sounds like turbo is not the way to go thx guys...and girls
"My heroes are those who risk their lives every day to protect our world and make it a better place - police, firefighters and members of our armed forces."
Grants99TJ is offline
post #30 of 209 Old 09-09-2008, 05:40 AM
Johnmac
2011 WK
Originally Posted by Grants99TJ View Post
... what are the advantages disadvantages and what is the best one. Are there any kits out there, prices ideas... anything that may help me out...
This thread from Redrock4x4 was doing the rounds back when I was considering a Turbo.
It's an excellent thread with lots of info and first hand experience.
Happy reading!
http://www.jeepforum.com/forum/f19/4-0l-turbo-kits-131751/
Johnmac is offline
any one know where i can buy a turbo for my jeep cmandes13 TJ Wrangler Technical Forum 15 10-24-2008 06:58 AM
turbo in a jeep? chino YJ Wrangler Technical Forum 21 10-03-2006 11:50 AM
supercharger and turbo charger ejmonkey3 TJ Wrangler Technical Forum 20 09-04-2006 06:08 PM
Jeep Turbo? Mueen TJ Wrangler Technical Forum 10 11-20-2005 04:54 PM
jeep turbo Lyle36 YJ Wrangler Technical Forum 3 05-27-2002 07:19 PM
