Jeep Tj 4.0 Turbo Charger - Page 14 - JeepForum.com
post #196 of 209 Old 08-14-2010, 06:02 AM
Sweeney
I've considered turbocharging my Jeep but have held off due to one thing... MA state inspections. Not because of any hardware or emissions but because MA plugs into the diagnostic port and I feel to do this properly you need a programmable engine management system.
The hardware would be simple and the tuning would be 'relatively' simple. I'm partners with a friend in www.TurboChargingDynamics. We design and built systems for older BMWs.
On the subject of 'turbo lag'... SAAB figured that out almost 30 years ago. You simply need to design the system correctly.
Heat... you always see pictures of glowing turbine housings and manifolds on turbo engines. Notice they are always taken in low light. Iron based metals glow red at about 1100 degrees F in low light... a .72 Pinto engine will glow if you flog it for a while.
Sweeney is offline
post #197 of 209 Old 08-14-2010, 08:00 AM
NOPLANS
Originally Posted by Vodkaman View Post
The main problem for turbo on Jeep motor is fuel management not a turbo lag. I've been following turbo threads for a long time, and have not found any finished setups! Everything stops on starting engine when turbo is put on, and then endless screwing with injectors, piggybacks and intercoolers. It is so strange, a lot of good turbo motors (srt4 included) and no reliable solution for turbo management yet!
This one has been on the rocks, in the water for three years now. No turbo failure, no eng failure, The piggy back ftc1 has worked perfectly after getting if set up, It takes a couple of days & a few phone calls. Then you can tune it perfectly.
NOPLANS is offline
post #198 of 209 Old 08-14-2010, 08:33 AM
littledevilTJ
NOPLANS where are you located in florida? I really like your rig.
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
post #199 of 209 Old 08-14-2010, 09:12 AM
NOPLANS
Saint Petersburg
NOPLANS is offline
post #200 of 209 Old 08-15-2010, 04:55 PM
Vodkaman
Sounds like joke. You live in Saint Petersburg, I live in Moscow, but not in US. In Russia! And I've seen a lot of pictures of turbo installed, but no one finished. I mean compleated and satisfied with how it works.
Vodkaman is offline
post #201 of 209 Old 08-15-2010, 07:00 PM
NOPLANS
Never been to Moscow. east berlin is the closes to russia I've been
Well this one is completed, and very satisfied with the results, This was my design and hand built by me, about 2k in parts & lots of labor to build the first one. I am running 12lb of boost, 36lb fuel injectors, t3/t4 turbo mounted to the custom header, and a ftc1-e fuel & timming managment system kept all stock emission items on the engine.
NOPLANS is offline
post #202 of 209 Old 08-15-2010, 07:45 PM
J03_TJ
Can you pass smog emissions? If so. send me a pm.
J03_TJ is offline
post #203 of 209 Old 08-16-2010, 06:18 PM
blkbird95
I posted several pages back, but my system is no longer remote. As of last winter my 98XJ with the 4.0 has a t3/t4 mounted to a custom manifold under the intake, 38mm tial style wastegate with tial guts, subaru legacy bypass valve rerouted, 36lbs ford red tops, Crane HI-6 with timing retard, Aeromotive DFMU with Walbro 255lph inline, Synapse Missing Link, AEM meth injection, and of course AEM wideband. I had to go with bigger injectors because a factory injector started leaking at the body (I had supercoupe injectors laying around). I think the pressure from the DFMU system killed it.
Just passed NY state inspection, which for my area is the regular visual and no check engine light and readiness monitors must be ready. For my 98 I can pass without 2 of the readiness being set. For you later guys with the pre-cats, I am sure there is an electric bypass available if you "move" them. I am running 8lbs, spool-up is fast and it suprises everyone that rides with me. Merging on the highway is a lot of fun! It has been turbocharged for 2 years now. Its my toy so I will alway be trying to improve it, like a bigger turbo, or a different fuel system, but as far as being satisfied....hell yeah! Wouldn't want it any other way!
Brad
blkbird95 is offline
post #204 of 209 Old 11-21-2010, 02:53 PM
FusionWelding
subscribed
FusionWelding is offline
post #205 of 209 Old 12-07-2010, 02:32 PM
Maverickxeo
Ill have to read through this when I get home from work... I have my old T3 out of my 300zx I will have sitting, taking up space...
Maverickxeo is offline
post #206 of 209 Old 12-07-2010, 04:25 PM
basssolow5
this was post #2 on page one. i thought it was great!
Originally Posted by litebrite2001 View Post
Pros:
Being able to beat a Toyota Prius in a drag race.
turbo. $1000. all needed plumbing $450. new tires $843. beating a prius in a drag race,....... priceless! lol
colorado jeep club member #730
stimulating the economy one part at a time!
basssolow5 is offline
post #207 of 209 Old 02-07-2011, 05:31 PM
dameye924
How much would it cost to have someone put a turbo on my jeep?
dameye924 is offline
post #208 of 209 Old 02-07-2011, 05:35 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
call up 505 Performance.
http://www.505performance.com/
you'll need to drive to the southwest....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #209 of 209 Old 08-05-2013, 10:08 AM
2k2wranglerx
dragging up an old thread....
http://www.shop.505performance.com/p...&categoryId=15
looks like it comes with an air/water intercooler...
anyone run this kit currently?
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
any one know where i can buy a turbo for my jeep cmandes13 TJ Wrangler Technical Forum 15 10-24-2008 05:58 AM
turbo in a jeep? chino YJ Wrangler Technical Forum 21 10-03-2006 10:50 AM
supercharger and turbo charger ejmonkey3 TJ Wrangler Technical Forum 20 09-04-2006 05:08 PM
Jeep Turbo? Mueen TJ Wrangler Technical Forum 10 11-20-2005 03:54 PM
jeep turbo Lyle36 YJ Wrangler Technical Forum 3 05-27-2002 06:19 PM
