Jeep Tj 4.0 Turbo Charger - Page 11 - JeepForum.com
post #151 of 209 Old 10-29-2009, 06:03 PM
rs4race
Hmm so is this thread just an idea of a turbo or did anyone on here actually put one on yet?
I used to run a nissan 240sx with a built sr20det. I made 300ft lbs and 400rwhp. That was on a gt2871r .64 ar.. in this application I spooled 18psi by 2700rpm and the 300ft lbs was made at about 3000rpm flat torque curve to redline.
This turbo would be plenty big for a 4.0.. If you had some money to custom fab your own stuff you could make a very balanced motor out of the 4.0.. I would guess it would be very torquey and you would probably break parts.....
I saw someone menchion ecm or ecu tuning. I have experience eeproming a nissan ecu and tuning it but cant find much for the jeep. Im guessing that the jeep maps are really conservative, and you could pull out a quite a bit more effeciency and power out of the motor.
Anybody have any info on tuning the jeep ecu?? I saw something menchioned about an obdII tuning....
rs4race is offline
post #152 of 209 Old 10-29-2009, 06:12 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
re-read through the thread. there are links to quite a few turbo 4.0Ls in this thread...its been done and works great if properly designed. I've seen and ridden in a 03 Rubi with a homebrew/505 turbo kit. It was pretty sweet.
tuning a TJ's ECU is a big challenge. you can't tune the stock ECU, the code hasn't been cracked, and it doesn't have the hardware required. Therefore you need a piggyback ECU that can read wideband 02 sensors and a 2-bar MAP. The SplitSecond FTC-1 and the Unichip Q are the most common, easiest (and only) choices for the most part. The Unichip Q must be dyno tuned by a Unichip authorized shop. The SplitSecond FTC-1 can be trial and error tuned by a laptop, but it puts your engine in major jeopardy. A dyno tune is the best way to ensure you've got a safe A/F ratio and no knock.
Search for piggyback ECU and turbo/supercharger/stroker stuff using my name, i've posted tons of info on this forum with regard to that. Reelm'n Rubi and Robert J. yates are also very knowledgable people who run highly modified engines.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #153 of 209 Old 01-20-2010, 07:11 PM
BlueOvalBud
1976 CJ8
WOW!
Great info!!!!
I typically hang out in the CJ forum, but have become interested in turbos recently. I just spent the last hour reading this thread: start to finish.
I have a couple questions, they may exist somewhere on the internet, but this thread seams like a good place to add any other turbo info for a 4.0.
So, low end boost requires a smaller turbo. One member has a turbo with a .63 hot side and has great success of achieving boost from idle up.
Top end boost requires a larger turbo, giving boost more lag but giving a higher RPM range. Jeeps aren't exactly meant for high RPM's (6k area!)
What I'm missing is numbers.
Low end boost. I only read one or two posts stating they felt boost from 1,200 RPM's up. But where did it stop boosting?
I'm interested in the turbo setup on a 4.0 as well as all others who have contributed to this overwhelming amount of knowledge, my head is spinning!
I figure to properly size a turbo, we must start with the Jeep's intended application.
Myself, my CJ is a farm Jeep that sees most of it's time "under load". The low RPM range of the 258 is fine for me so I assume the 4.0 will still be fine for me. (I plan on swapping a 4.0 and associated electrical into my CJ in order to do the turbo) What lacks is when I start pulling my heaped utility trailer of heavy green firewood out of the woods uphill. I could really use some extra boost! Beginning around 1,000 RPM and ending around 4,000 would be ideal for my application.
I know i'm shooting for a small turbo, but do all the numbers mean? .63 hot side looks like my size...
Thank you to all the knowledgable guys who have shared their knowledge!
Scrambler - a Nuttin' Special Budget Build from the ground up. '76 CJ7 Drivetain in a Scrambler. 258, T18, Dana 20, Dana 30, AMC 20, Fiberglass Tub, Team Rush, Glasspack
'84 CJ7 - A frame-off resto for my sister's daily driver! 258, T4, D300, D30, AMC 20, Widetracks
BlueOvalBud is offline
post #154 of 209 Old 01-24-2010, 07:51 PM
NOPLANS
Run a .63 Hot / .50 Cold, Your not realy producing much boost at a 1000RPM but you will gain torque, You will need 30# fuel injectors, split second FTC1-E, Here is a pic of my plumming
NOPLANS is offline
post #155 of 209 Old 01-24-2010, 08:11 PM
Unlimited04
nice, what are you using for a manifold? how is the turbo mounted? What brand turbo, what trim? Do you have any heat shield setup? Any pics with the intake manifold off? How much boost? Dyno results?
MORE INFO!
Useful Write-Ups:
Funny:
post #156 of 209 Old 01-24-2010, 10:46 PM
sourskittle
Sweet, where in FL are you ?
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s
sourskittle is offline
post #157 of 209 Old 01-25-2010, 05:34 PM
NOPLANS
MORE INFO!
I am using a header I built with a t3/t4 turbo flange, The turbo is a cxracing t3/t4 .63 hot / .60 cold. ceramic coated header no heat shields, I am running 8psi of boost, No dyno runs, This is a 4.6 stroker, 42# fuel injectors, 2 1/2 stainless steel exhaust with a hushpower muffler, no catalatic converter. I will post a pic of the header later this week. Heres a pic of the under side, You can see were the turbo sits with my setup.
NOPLANS is offline
post #158 of 209 Old 01-25-2010, 06:36 PM
Unlimited04
^^ interesting setup. what are you doing for a wastegate?
Useful Write-Ups:
Funny:
post #159 of 209 Old 01-26-2010, 12:43 AM
sourskittle
Ummm, no really, where are you from, haha...
post #160 of 209 Old 01-26-2010, 03:13 AM
NOPLANS
St Pete! I am running a waste gate on the turbo & a BOV.
NOPLANS is offline
post #161 of 209 Old 01-26-2010, 05:02 AM
ozo101
ozo101's Avatar
Originally Posted by onlyn8v View Post
What top end? Its a Jeep.
hehe good one! I dont remember ever going up there, and why would you want a faster jeep? I did 90mph on 78 the other day just to see how fast it would go and it did not feel safe at all and my jeep is stock height with impecable steering and drivetrain
well who doesn`t like a jeep
ozo101 is offline
post #162 of 209 Old 01-26-2010, 11:26 AM
sourskittle
That pic of the jeep rolled over wasn't local then, huh... I'm not that far from ya, I'd like to see that thing one day. May we can do a turtle race !!!
Also who built the suspension on your TJ ?
post #163 of 209 Old 01-26-2010, 12:13 PM
NOPLANS
That was at a private house in Brooksville. I built everything or bought and modified everything on the jeep.
NOPLANS is offline
post #164 of 209 Old 01-26-2010, 12:50 PM
Unlimited04
awesome....looks like quite a setup. hows the low end torque?
Useful Write-Ups:
Funny:
post #165 of 209 Old 02-24-2010, 09:57 AM
jeepspeed98
Ok guys i just joined this thread to find out info cuz like everyone else im planning on the turbo setup. i was on another forum homemadeturbo.com doesnt seems much like a usefull place but just seeing what they had to say. anyways was talking with one of the guys there telling me i need an HX35 or HX40 holset cummins turbo...???
Just to give some info about my jeep and plans on it..
since i live in miami fl i dont have much rock or anything to climb so im looking for more horsepower.. i see here that you can only put so much but what i would like to know is how much can i really boost.. Also i have a 2wd so so much for offroading. Im planning on building a street jeep lower suspension if can be possible which i think will can be.. turbo charged.. aussie locker... roll cage.... black rock wheels... and a few misc.. upgrades stereo racing seats and harness...
**please i know im going to get it but not to much trash talk about lowering it im not slammin it just to give better center of gravity**
Anyways back to the turbo im goin to put in a set of pacesetter headers.. not sure on turbo size yet... ext. wastegate... i run the exhaust either straight back or off to the side.. this is the turbo the guy i mention before was talking bout...
HX35 or HX40 cant seem to find specs on right now im have one hell of a brain fart.. post when i find
so let me know.... all suggestions welcome
jeepspeed98 is offline
any one know where i can buy a turbo for my jeep cmandes13 TJ Wrangler Technical Forum 15 10-24-2008 05:58 AM
turbo in a jeep? chino YJ Wrangler Technical Forum 21 10-03-2006 10:50 AM
supercharger and turbo charger ejmonkey3 TJ Wrangler Technical Forum 20 09-04-2006 05:08 PM
Jeep Turbo? Mueen TJ Wrangler Technical Forum 10 11-20-2005 03:54 PM
jeep turbo Lyle36 YJ Wrangler Technical Forum 3 05-27-2002 06:19 PM
