Jeep still smells hot months after SYE install - JeepForum.com
post #1 of 8 Old 12-21-2006, 06:05 PM Thread Starter
01amberfirewv
I installed an SYE last summer and noticed that it smelled hot (I know hot has no smell but you know what I mean) after driving, especially at higher interstate speeds. When I first noticed it I thought it was just the woody shaft throwing grease on the exhaust but I still smell it. I remember using a small precision screw driver to push the pump back up on the plate but is it possible that it fell back down after the install? Could it be due to my pinion angle being slightly off?
33x10.50 BFG MT KM2 on soft 8's , 4.88's Super35, D30ECTED, OME HD, AtoZ rockers, skid plates, custom rear bumper, Champion winch, SYE, Woody shaft, 4.0tb, Rocket parts intake, Magnaflow muffler
01amberfirewv is offline
post #2 of 8 Old 12-21-2006, 07:10 PM
farinspace
i had troubles too with getting the pump pipe/hose back on the fitting, it has to snap into place, i almost let it go thinking it was ok, but decided to force it a bit more until it snapped into place ... i then was convinced it was on.
Let the jeep cool for a bit and get under it see if you can pin-point the smell ...
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline
post #3 of 8 Old 12-21-2006, 08:50 PM Thread Starter
01amberfirewv
I do remeber it clicking into place but that is the only thing I can think of. I'll have to try the sniffer test again
post #4 of 8 Old 12-21-2006, 09:03 PM
jrtdogbone
jrtdogbone's Avatar
It's most likely grease from your sye spraying on the muffler- tailpipe. Everytime you grease the sye, it only needs a bit. It's easy to over-grease and whala, you get that smell like something's burning up.
You're just having the " Didn't I get that TC Oil Pump on correctly freak-out."
The Dog
The Dog
2004 Jeep Willys
jrtdogbone is offline
post #5 of 8 Old 12-22-2006, 04:58 PM
DaveE
I just installed a Tom Woods SYE and had the same experience. I crawled under it and there was grease all over from the U-joints. It really smells when the muffler is hot.
I had the same worries about the oil pickup being seated properly in the oil pump. However, I think that the pickup tube to the oil pump can't come out if it was pushed in adequately. I think the bottom of the t-case will hold it in place.
You could always drive it for a while, crawl under it and put your hand on the t-case if you are still worried.
DaveE is offline
post #6 of 8 Old 12-22-2006, 05:03 PM
coorsmgood
coorsmgood's Avatar
2010 JK Wrangler
I had the same problem but it was cause I did the speedo gear at the same time and the tranny fluid was leaking out of the speedo gear just enough to blow a drop back once in a while...just a thought as I could hardly notice the leak by looking at it?
2010 4 door wrangler stock for now in burnt orange longhorns style!!
coorsmgood is offline
post #7 of 8 Old 12-22-2006, 07:08 PM Thread Starter
01amberfirewv
I just looked and there is some oil around the output shaft seal. I may have a small leak there but I don't know if any is comming out or not. I'll have to keep looking around. Thanks for all the suggestions
post #8 of 8 Old 12-25-2006, 08:42 AM
Kentuckyarms
Kentuckyarms's Avatar
I also smell the same burning odor. I believe it is grease from the Tom Woods drive shaft. I know it isn't the SYE because I used the Hack n Tap version.
2012 JK Sport
3.6L
5 Speed Auto
RE 2" Budget Boost
285/75/16 MT
Kentuckyarms is offline
My jeep interior is wet and smells ? chaznad TJ Wrangler Technical Forum 10 07-02-2009 04:29 PM
How to eliminate smells from the Jeep MB98XJ TJ Wrangler Technical Forum 29 01-10-2009 09:42 PM
undercaradge smells HOT after the SYE install 01amberfirewv TJ Wrangler Technical Forum 13 09-09-2006 10:21 AM
Install Aussie locker for Mar-Oct, remove for Nov-Feb snow months? planman TJ Wrangler Technical Forum 4 05-22-2006 10:31 PM
my jeep smells zuck2001 YJ Wrangler Technical Forum 13 10-26-2001 01:03 PM
