Jeep starts, then stops... - JeepForum.com
post #1 of 14 Old 08-05-2005, 09:45 AM Thread Starter
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Hey Guys,
Check this out...it's happened twice in the past couple of months. I get into my Jeep (1998 TJ 4.0L w/ auto tranny) and it starts right up, but if I let go of the gas pedal, it dies, will NOT idle. I'll start it again, rev it up, but again, when I let go of th pedal, it dies. So...I start it again, and if I get it into gear and drive, even if it's just twenty or thirty feet, then it's fine, idles and drives like a dream, and it's like nothing ever happened. Both times, it has had plenty of gas, 1/4 to 1/2 tank.
Has anyone ever experinced this? Any thought are appreciated!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #2 of 14 Old 08-05-2005, 01:17 PM Thread Starter
Steelman
Steelman's Avatar
Everyone stumped like me???
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #3 of 14 Old 08-05-2005, 02:48 PM
jeepwrangler268
blown fuse? that happened to me.
check ur fuse box
RIP
2000 JEEP WRANGLER SPORT
<----- Before Lift
4.0 L 5 Speed Manual
Dana 30, Dana 35
31' BFG MT's on Canyon Wheels
Rockers, H4 Hid Conversion 6000k,
2 Hella Rallye 4000's, 2 Hella Rallye 500's,
H4 conversion, 2 inch Rusty's Coils,
New 3 Core Radiator, TrucK Master hood scoop,
Cobra 19DXIII cb, Firestik antenna, Rock It Tail light cb antenna mount[COLOR=Red]
jeepwrangler268 is offline
post #4 of 14 Old 08-05-2005, 02:56 PM Thread Starter
Steelman
Steelman's Avatar
check ur fuse box
If it were that, would it be so random, and then start up again like it does?
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #5 of 14 Old 08-05-2005, 06:00 PM Thread Starter
Steelman
Steelman's Avatar
Any ideas anyone???
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #6 of 14 Old 08-05-2005, 06:07 PM
subaruboy
idle air control valve? this controls the air entering the engine when you're not pushing the gas, and if it's bad, it could potentially be cutting off all air to the engine when you're not physically opening the throttle body with your foot
Originally Posted by Steelman
Any ideas anyone???
00 Jeep TJ SE Amberfire Pearl- Sold :'(
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
subaruboy is offline
post #7 of 14 Old 08-05-2005, 08:51 PM
msmith97TJ
I've had similar happen in my 97, although it is not an automatic.
basically it would not keep an idle for the first few minutes, but
once I drove it for a bit it would keep idle.
The problem was I needed to replace my battery- I killed it too many times
msmith97TJ is offline
post #8 of 14 Old 08-07-2005, 02:08 AM Thread Starter
Steelman
Steelman's Avatar
This sounds like something I need to look into. How dificult is this repair? Wouldn't think it could be the battery as it's fairly new, and I have never 'killed' it!
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #9 of 14 Old 08-07-2005, 08:18 AM
subaruboy
i'm not sure about the jeep, but on my old monte carlo it wasn't too difficult.
are you getting the check engine light coming on when you're running the jeep?
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
post #10 of 14 Old 08-08-2005, 12:53 AM Thread Starter
Steelman
Steelman's Avatar
The check engine light did come on for a while, then it went off later that same day (the first time this happened). It did not come on the second time this happened...
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #11 of 14 Old 08-08-2005, 06:58 AM
subaruboy
take it to an advace auto and get the codes read... there should be some stored in the computer
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
post #12 of 14 Old 08-08-2005, 07:37 AM
jeep_chinto
do you have a key that has a grey top to it possably the transponder or recever in it has gone bad most likely the recever in the steering collum just a thought
jeep_chinto is offline
post #13 of 14 Old 08-08-2005, 10:29 AM Thread Starter
Steelman
Steelman's Avatar
My key is just the standard key with the black plastic head on it. Positive that there is no electronics in it.
I guess getting the codes read makes sense...just gotta find the time!!!
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #14 of 14 Old 08-08-2005, 11:44 AM
Jayoh
subaruboy is almost definitely right, it sounds like the idle air control valve, I've had this problem myself in a different car. Its probably a good time to change your fuel filter and air filter if you haven't done these in a while.
You might notice its worse if the A/C is on, and if its especially humid and hot outside.
Also, it might let off once it reaches operating temperature.
Jayoh is offline
Engine Starts and then Stops after running 2 Seconds 11990YJ YJ Wrangler Technical Forum 3 03-15-2009 10:41 AM
Used replacement 2.5L motor starts and immediately stops jeepman1994 YJ Wrangler Technical Forum 3 02-07-2009 04:34 PM
It never stops with a Jeep does it? Pittsbuilder YJ Wrangler Technical Forum 12 01-11-2009 10:22 PM
Digital Odometer Stops and Starts rschulten TJ Wrangler Technical Forum 0 05-11-2008 05:38 PM
89 yj starts but stops within 5 seconds Peterkalidonis3 YJ Wrangler Technical Forum 2 10-04-2006 08:51 AM
