jeep starting problems - JeepForum.com
post #1 of 4 Old 03-08-2012, 01:25 PM Thread Starter
MarshallMopar
I got a 00 tj 4.0. After I let it sit for about 5 or 6 hours it has a lot of trouble starting.
It turnns over and everything it just won't fire up like it should. After a little bit it will start.
Once the jeep is running for a little bit I can shut it off and it will start right up. And everything is normal. Just seeing if anyone has had this problem and maybe someone more experienced can help me figure out what it is.thanks!!!!
MarshallMopar is offline
post #2 of 4 Old 03-08-2012, 01:28 PM
achiever
trouble starting
Could be Fuel pump. Had 2 jeeps do this. Began having trouble starting then settled in to turn over crank no start, turn off, fires right up. $500-600 at a shop. Less than $200 part, really easer than you'd think. Run it dry, Drop the tank, swap the part. Only a few bolts hold the tank and the filler nozzle.
achiever is offline
post #3 of 4 Old 03-08-2012, 03:21 PM
Ross00TJ
Duplicate thread: http://www.jeepforum.com/forum/f9/je...blems-1340139/.
OP, mdm's post in the original thread is the best answer. If your fuel pump was going, you would have problems running as well.
Future Electrical and Computer Engineer - University of Colorado - Boulder | Bringing Logic to JeepForum since 2010!
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Ross00TJ is offline
post #4 of 4 Old 03-11-2012, 10:01 PM
achiever
No. I never had problems running. Just wouldn't start on the first try.
achiever is offline
sensor , starting
Jeep Starting Problems Dioxide TJ Wrangler Technical Forum 4 07-01-2012 05:46 PM
95 jeep starting problems roadkingjim YJ Wrangler Technical Forum 3 10-04-2010 09:05 PM
Problems starting the jeep. trek301 TJ Wrangler Technical Forum 4 11-03-2008 08:38 AM
More jeep starting problems... Quick636 YJ Wrangler Technical Forum 14 11-11-2005 11:26 PM
Jeep starting problems y(j)me YJ Wrangler Technical Forum 7 12-20-2002 07:09 AM
