jeep stalls after driving long distances .. help - JeepForum.com
post #1 of 10 Old 01-04-2006, 12:21 PM Thread Starter
Pizzaboy04
trI have a 97 jeep wrangler ..4cyl 5-spd .. truck runs great till about and hour or so .. if i rev over 3000 rpm the truck loses power .. seems like runnin out of gas .. i have to pull over let the car sit then start it up again .. what is it ?? the gas tank caroding ? fuel pump ??
Pizzaboy04 is offline
post #2 of 10 Old 01-04-2006, 12:30 PM
jeeptj19992001
vapor lock
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #3 of 10 Old 01-04-2006, 12:31 PM
Grimmjpr
Sounds like your fuel pump is tired. I had a friend with an XJ she could drive for 2.5-3 hrs run great then die.....wouldn't start again unless it sat for a while. let is sit over night it would run another 2.5-3 hours......the shop she took it too replaced everything but the pump.....she kept getting stuck....finnally i told her to have them replace the pump......no problems at all once the pump was replaced. Hope this helps....
2012 JK Rubi - Cosmos Blue/5 speed auto
04 TJ Electric Lime Green Rubicon - Bunch of extras. Cha-Ching - Gone
97 TJ Lapis Blue Sport - Gone
Grimmjpr is offline
post #4 of 10 Old 01-04-2006, 12:36 PM Thread Starter
Pizzaboy04
Originally Posted by jeeptj19992001
vapor lock
vapor lock ??
post #5 of 10 Old 01-04-2006, 12:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Does the engine suddenly just die? If so, that's a common symptom of the crankshaft position sensor going bad. Residing on the bell housing, the CPS picks up pulses from the flywheel and provides the master timing signal for the engine.
Gone on vacation until August 25.
Jerry Bransford is offline
post #6 of 10 Old 01-04-2006, 12:44 PM
RubiconSS
RubiconSS's Avatar
Originally Posted by Pizzaboy04
vapor lock ??
Kinda like when you are chugging coke out of a bottle and you get to the point where no more soda will come out. Usually a can of dry-gas or driving with the gas cap off will help. But, it's probably more along the lines of what Jerry was saying. Although, this can be a time of year for vapor locks. Does it happen when the tank is full or only when it's somewhat empty?
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline
post #7 of 10 Old 01-04-2006, 12:56 PM Thread Starter
Pizzaboy04
that is exactly what happens .. and alwayz after driving awhile .. then acouple times when i hit bumps it would happen .. ussually when half or less
post #8 of 10 Old 01-15-2006, 11:07 AM
Bob71
Check and see if the fuel lines are near the engine or exhaust. If so, you can buy line insulation (looks like aluminum foil) and wrap it around the fuel lines.
Vapor lock accurs when the gas boils and causes the gas to turn into vapor. This will accur faster the warmer the outside temp. is. If it's cold outside, it may never happend.
Bob71 is offline
post #9 of 10 Old 01-22-2006, 08:18 AM
CaymanYJ
I had the same issues except that it would happen after about 45 minutes of driving. If you left it for a while it would be fine again. Replaced the coil and it was all fixed. Once the coil heated up it would fail.
CaymanYJ is offline
post #10 of 10 Old 01-22-2006, 08:35 AM
Scott_98TJ
You can rule out vapor lock.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
driving long distances jenkins_1120 Wrangler General Discussion 14 09-03-2009 04:22 PM
rear end shutters when pulling out after driving long distances...whats the problem?? bortz1892 TJ Wrangler Technical Forum 9 08-29-2009 03:04 PM
Driving long distances in your jeep mightydog78 TJ Wrangler Technical Forum 40 06-07-2009 11:49 PM
Jeep 'almost' stalls when driving fjmd3 YJ Wrangler Technical Forum 15 03-25-2009 02:17 PM
driving long distances ryan188 TJ Wrangler Technical Forum 52 10-25-2007 08:48 AM
