jeep running lean after water - JeepForum.com
post #1 of 6 Old 07-30-2010, 02:54 PM Thread Starter
Skidoox593
I went through water last weekemd jeep died so I had to dry out the distribter it runs now but is still throuwing 51 and 12 cel I changed the oil and air. Filter and still burnt a quarter tank of gas in 25 miles any suggestions
Skidoox593 is offline
post #2 of 6 Old 07-30-2010, 07:28 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Start by checking and cleaning all the engine control connections. One may be dirty etc. It's a place to start and it's free to check and clean them.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 6 Old 08-05-2010, 09:38 PM Thread Starter
Skidoox593
i think it is finally fixed after putting in a new o2 sensor(orig. 80k and black) and spark plugs $55 which was cheap compare to changing the fluid in both differentials, transmission(Redline MT-90), transfer case, and engine oil.......all in all i figure i will stick to just mud and no more 3.5ft deep puddles
post #4 of 6 Old 08-05-2010, 10:05 PM
LiveAndLearn
will all of the o2 sensors give you bad gas milage?
LiveAndLearn is offline
post #5 of 6 Old 08-05-2010, 11:23 PM
littledevilTJ
spark plugs for $55????
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
post #6 of 6 Old 08-06-2010, 05:37 AM Thread Starter
Skidoox593
That was the cost of the o2 sensor and the plugs
lean
running lean.....what causes that? cmorganf64 TJ Wrangler Technical Forum 11 09-27-2011 08:00 PM
2.5 running too lean? psycopanther TJ Wrangler Technical Forum 0 06-04-2009 05:31 PM
Engine running lean - Need Help! ragef22 YJ Wrangler Technical Forum 4 07-21-2008 09:42 PM
No Power...running Lean? huffjdeere YJ Wrangler Technical Forum 0 07-02-2008 01:47 PM
Running lean coolhand YJ Wrangler Technical Forum 2 03-24-2007 02:08 AM
