Jeep rear sits unlevel - JeepForum.com
post #1 of 7 Old 06-24-2007, 10:37 PM Thread Starter
aklsufan
I picked up a 99 wrangler and noticed that the right rear sits about 1/2 lower than the left rear side. It has the 2 inch budget lift with new shocks, I am wondering if the right rear spring is just weak and needs to be replaced? There is currently no spare mounted so there is no added weight to the rear.
aklsufan is offline
post #2 of 7 Old 06-25-2007, 08:43 AM
tcox
you could try swapping the rear springs around....over time they might even out
stuff
tcox is offline
post #3 of 7 Old 06-25-2007, 09:41 AM
Jerky bump
I hope it's not a twisted frame.
Jerky bump is offline
post #4 of 7 Old 06-25-2007, 11:21 AM
Combatsylvania
id keep my eyes open for a set of stock springs off a rubi or sport (can be had cheap when someone upgrades) and see if that helps..
Chances are its just sagged
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #5 of 7 Old 06-25-2007, 11:25 AM
JEEP-DADDY
JEEP-DADDY's Avatar
mine did the same thing, I replaced the springs and that solved the problem......
Steve
2005 LJ
JEEP-DADDY is offline
post #6 of 7 Old 06-25-2007, 02:07 PM
Fargo
How does the front look. If the frame is strait, I would think the opposite corner of the front should sit a little higher due to the sagging in the rear. But I don't know for sure. I would guess that the spring is just wore out. I know some companies (OME) sell springs with different rates for each corner due to sagging cause from engine torque (I believe).
6spd manual
LJ Owners Group member #110
Fargo is offline
post #7 of 7 Old 06-25-2007, 02:26 PM
tcox
oh oh oh i have a set of stock springs from my sport....id love to get rid of them....PM me for details
stuff
tcox is offline
Jeep sits a little uneven AlexGeorgakis TJ Wrangler Technical Forum 53 12-25-2010 01:56 PM
Jeep Unlevel lukera TJ Wrangler Technical Forum 6 03-07-2010 12:30 PM
Fabtech Lift Installed And Now Front Sits Higher Than The Rear rboppre YJ Wrangler Technical Forum 12 03-05-2009 06:13 AM
Rough Country4"x install, unlevel rear chutta TJ Wrangler Technical Forum 3 04-27-2007 07:16 PM
jeep sits lower on the right 97TJGUZZY TJ Wrangler Technical Forum 16 02-14-2003 11:45 PM
