Jeep Radiator Problem, you too? - JeepForum.com
post #1 of 21 Old 12-16-2009, 09:19 AM Thread Starter
Tjosh97
Just curious I had two Jeep TJs radiators start leaking this on two seperate TJs. Then, a guys at my work his Cherokee started leaking too. Anyone else just curious all three at the same time seems like a big coincidence. Have a good one!
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline
post #2 of 21 Old 12-16-2009, 09:20 AM
finsout
the stock radiators are junk. get an all metal one. easy install.
finsout is offline
post #3 of 21 Old 12-16-2009, 09:30 AM
Wif
Wif's Avatar
Bad things happen in threes .. didn't you know that
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #4 of 21 Old 12-16-2009, 09:34 AM
xltj
The stock radiator is known to separate along the plastic end caps where the metal is crimped. Although I recently bought a replacement OEM style (knowing this will happen again. ) from a local radiator shop. I wasn't completely sold on getting an all metal radiator because I did read about problems with those as well. Chances are an all metal radiator would be better. But I'd rather just have to drive my new radiator to a local shop than ship it off in the case that it breaks.
xltj is offline
post #5 of 21 Old 12-16-2009, 09:58 AM
bige2533
The Jeep's radiator is a pretty easy replacement. That was my first repair I did on my own Jeep. Check out the writeup at Jeep TJ Web Site of Stu Olson - N7QJP
bige2533 is offline
post #6 of 21 Old 12-16-2009, 10:40 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
All brass radiators are junk also, IMO. In a TJ, those have problems with the core tubes seperating from the tanks...
Knuckelhead is offline
post #7 of 21 Old 12-16-2009, 10:47 AM
Jeepster83
i recently replaced mine with an OEM one with plastic tanks. i figure that i got almost 100k out of the old one then i should get the same out of another one as long as i keep driving the way i do.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #8 of 21 Old 12-16-2009, 12:26 PM Thread Starter
Tjosh97
Thinking about getting a CSF Radiator with aluminum core or maybe Ready-Rad radiator with aluminum core..... but I just thought it was crazy that all three jeeps started leaking. Maybe a jeep villain going around poking holes...lol
Tjosh97 is offline
post #9 of 21 Old 12-16-2009, 12:27 PM Thread Starter
Tjosh97
yep.....btw NICE pic!
Tjosh97 is offline
post #10 of 21 Old 12-16-2009, 12:34 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
It's not just Jeeps. Scads of vehicles out there use aluminum cores clamped to plastic tanks. My F-350 (7.5) rad was leaking a few years ago, and I replaced it with an all-aluminum radiator, to the tune of six hundred bucks!
If you do go with an all-aluminum radiator, be aware that you MUST use distilled water in the coolant mix, after using distilled water to flush all the old coolant from the system.
It is very possible for tap-water mixed coolant to conduct electricity (usually because of a bad ground on the engine). Over time, the electrical current flowing through the coolant to ground will eat through the radiator, one molecule at a time. It's the same as electroplating, but in reverse... the molecules of aluminum are lifted from the inside of the radiator and are held in flux in the coolant. If the inside of your filler neck is dark gray or black, it's happening.
Distilled water does not conduct electricity, so using distilled water in your coolant mix effectively stops the electrolysis.
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #11 of 21 Old 12-16-2009, 12:56 PM
xltj
My same thinking. 10 years and 74k miles. If I get that out of the new radiator I'll be happy. Who knows if a rock will get to it before then
xltj is offline
post #12 of 21 Old 12-16-2009, 12:57 PM
crusty1007
Im using a Visteon Core with Tig welded Aluminum tanks.
Using spring style washers to clamp it to the grill assembly.
I haven't had any issues since tossing the brass/copper assembly away. (it was only in for a little over a year & the mounts tore from the cores, I assume from vibration & bouncing around. It looked pretty ragged & was also leaking from a core.)
The Alu. one has been in it for 2 years & looks good as new.
If you go Alu. just make sure to use DI water & proper coolant.
The Alu. also offers better cooling efficiency.
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
crusty1007 is offline
post #13 of 21 Old 12-16-2009, 01:28 PM Thread Starter
Tjosh97
Great info and ya I always use distilled water when flushing and filling.
Tjosh97 is offline
post #14 of 21 Old 12-16-2009, 06:58 PM
Netpackrat
My original radiator started leaking at under 50,000 miles, and the all metal replacement was leaking less than 30,000 miles later. My Jeep has just over 89,000 miles and I am on my third radiator.
Netpackrat is offline
post #15 of 21 Old 12-16-2009, 07:07 PM
xltj
Just out of curiosity, where did you get your all metal replacement? And do you think that one leaked b/c of flexing?
xltj is offline
radiator problem lilmike386 YJ Wrangler Technical Forum 3 08-29-2009 03:06 PM
Radiator Problem MUDDYJEEP YJ Wrangler Technical Forum 18 01-16-2008 05:31 AM
2000 Jeep with radiator problem - and others - all helpful hints greatly appreciated tandbwms TJ Wrangler Technical Forum 5 10-01-2006 07:19 PM
3 row radiator problem k2snowboard YJ Wrangler Technical Forum 8 02-15-2006 08:27 AM
radiator problem hoosier724 TJ Wrangler Technical Forum 8 10-04-2004 11:18 AM
