Jeep overheats at idle... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep overheats at idle...
07-13 Wrangler 17x9 Wheels Free Shipping + $50 RebateHID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!
Unread 07-05-2008, 02:51 PM   #1
nonnaca
I have been having difficulty with my cooling system for a while now. My radiator, thermostat and water pump are new (as of 1 year ago). Recently some ******* took the radiator cap off unbeknownst to me. About 5 minutes into my commute the radiator boils over and I am stuck walking to a local auto parts store to get a radiator cap and put coolant/water in the radiator. Ever since then I have been having an issue at idle. The jeep tends to get warmer at idle, if I gas it the temp gauge goes back down. I have checked the top hose and it's warm telling me the thermostat works. I get hot air from the heater to my water pump works and the radiator is new. The fan is always on.
Ideas?
Thank you
Aaron
nonnaca is offline   Reply With Quote
Unread 07-05-2008, 02:54 PM   #2
the2040
have you checked the level of the fluid in your radiator? Sounds like you might have some air in it. Or maybe your fan clutch is not working.
the2040 is offline   Reply With Quote
Unread 07-05-2008, 03:02 PM   #3
BamaLonghorn
1980 CJ7
check to see if its the right cap. i replaced my radiator then got a new cap, it still would over heat, ended up the cap was wrong.
Originally Posted by sparkchaser View Post
You must be new here. A good 90% of arguments on Jeep Forum are built on gross generalizations and a framework of logical fallacies that fall apart under the slightest bit of scrutiny.
2001 Jeep Wrangler Sport - SOLD
1979 Jeep CJ-5 - Sold
1980 Jeep CJ-7
BamaLonghorn is offline   Reply With Quote
Unread 07-05-2008, 03:38 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
It sounds like there is air in the cooling system which needs to be removed by "burping" the cooling system. Here are a couple articles on how to do it but just be careful as the coolant is HOT.
http://www.olypen.com/craigh/cooling.htm
http://www.ehow.com/how_7369_burp-cars-cooling.html
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 07-05-2008, 03:54 PM   #5
lobukjeep
x2 on the fan clutch.
"We don't call you son 'cause your bright"
lobukjeep is offline   Reply With Quote
Unread 07-05-2008, 04:57 PM   #6
nonnaca
I will get right to work on "burping" the system. How do I check the fan clutch?
Unread 07-22-2008, 06:36 PM   #7
nonnaca
Burping the system worked like a charm. Thanks everyone!!
Aaron
