jeep over heating need help bad - JeepForum.com
post #1 of 5 Old 08-03-2005, 10:23 PM Thread Starter
jeep jake
My buddys jeep is over heating and we have replaced everything now. Originally we thought it was the thermostat, still over heated. Then we replaced the water pump cause it blew, it leaked everywhere. Then today we replaced the radiator after he brought it to a shop that was conviced it was the radator. We have blead the system, and it has new upper and lower hoses. The heat does not work. What could be causing this.
Please help
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
jeep jake is offline
post #2 of 5 Old 08-04-2005, 08:41 AM
rudyyj
is the upper hose getting hot? is the belt routed properly? is the pumps rotation correct? is the coolant flowing? is there air in the system?
scott
97 TJ
rudyyj is offline
post #3 of 5 Old 08-04-2005, 10:57 AM
AZSahara
AZSahara's Avatar
Check your fan clutch. When the engine is hot it should be locked solid. If you can turn it by hand with a hot engine it needs to be replaced.
John
L92/6L80 98 TJ
From the wilds of Northern Arizona
AZSahara is offline
post #4 of 5 Old 08-04-2005, 11:04 AM
Ragtop_Rob
Ragtop_Rob's Avatar
#1 Double check the belts
#2 Make SURE all of the air is out of the system!
#3 Make sure you put the thermostat in facing the correct way
#3 If the above do not fix it - and i really doubt this - try this - By pass the heater core with a short peice of hose (basically a "U") So where the coolant comes from the engine and goes into the firewall and heater core and comes back out of the heater core to return to the engine - we want to bypass the core all together.
Still i have a tough time imagining the issue is here - but the lack of heat is another indicator.
2005 Rubicon Unlimited Sahara #609 of 1000. 4 speed auto. Sirius Sat Radio, Mile Marker PE8000 Winch, 2" BB from Rocky Road, 32" BF Goodrich Radial TA/KO, RB1 NAV Radio with Ipod Controller
Ragtop_Rob is offline
post #5 of 5 Old 08-04-2005, 11:34 AM
rudyyj
the lack of heat has me thinking air or possioble no coolant flow
scott
rudyyj is offline
Jeep still over heating even after head job jeepwrnglr92 YJ Wrangler Technical Forum 202 05-30-2012 01:07 PM
jeep over heating at speed emahan01 TJ Wrangler Technical Forum 43 05-04-2009 05:47 PM
My Jeep Is Still Over Heating! 03WrnglerSahara YJ Wrangler Technical Forum 25 06-26-2007 11:17 AM
Over Heating jmeguiar TJ Wrangler Technical Forum 6 01-13-2006 06:46 AM
Over heating Jeep YJ 2.5L cody11ca YJ Wrangler Technical Forum 4 05-23-2005 04:23 AM
