Jeep Noise Diagnosis with Video! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep Noise Diagnosis with Video!
The Original 3/8" Ruffstuff Diff Cover!Safety Thimble FairleadsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 11-03-2014, 09:33 PM   #1
Pike80
Hello All,
I need help pin pointing this noise.
The jeep is a 2001 TJ with 157,000 miles. 4.0 I-6 engine. 5 speed NV3550 tranny, NV231 transfer case.
https://www.youtube.com/watch?v=J_sm...ature=youtu.be
Best example of the noise is at 1:07-1:19 and 1:24- 1:45.
The noise is heard when the clutch is depressed and when the clutch is released. The sound seems to go away after about 10-15 minutes of driving. It is best described as a whining/screeching/hissing belt or pulley noise, yet it SEEMS to be coming from the the transmission bell housing. Initial thought are the throw out bearing, but need help with diagnosis. Thanks for checking it out!
Pike80 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 08:06 AM   #2
Jeepsr4me
Sounds like a TOB... Good time to do a clutch, TOB and Pilot bearing
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 05:48 PM   #3
Pike80
Thank you for the input. Is it normal for a throw out bear that is going bad to make noise when the clutch is in AND out? Also, is it normal for a failing TOB to quiet down after drive around for awhile?
Unread 11-04-2014, 08:04 PM   #4
97lon
Interested in this, my 97 is making same noise. Going on a 2 hour drive for deer hunting this weekend and need my jeep!
97lon is offline   Reply With Quote Quick reply to this message
Unread 11-05-2014, 07:40 PM   #5
Pike80
TTT. Can anyone else weigh in on this? In the last couple weeks I did just finish installing a body light, motor mount lift, welding in Safe-T-caps, POR-15'ing the frame, installed OME lift and put on new tires and tailgate, I guess I could add the T.O.B. and new clutch to the list if that is truly what's wrong.
