Jeep modifications - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep modifications
GenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWarn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 06-01-2004, 02:59 AM   #1
booker's01jeep
Jeep modifications
I have a 2001 Jeep Wrangler Sport with a 4" skyjacker lift, K&N air intake, Jet chip module, 33 X 12.5 Firestone Duellers on 15 X 8" black American Racing Rims.
Can I put 35s on my 4" lift? Do I have to change my gears?
booker's01jeep is offline   Reply With Quote
Unread 06-01-2004, 06:07 AM   #2
NJ82TJ
You would probably want a spacer lift or a body lift to fit the 35's w/out rubbing. What gears do you have now? Generally when people go 35's they install 4.56 or 4.88's for a 5 spd.
2001 Green XJ Sport 4 spd Auto
Dana 44 swap with 4.88's & full spool
AA SYE w/ Tom Woods DS
C-rok steering brace
RE 5.5 Extreme Duty (not LA)
Swamper Q78's on 15x8 Soft 8's
Mild fender trimming
Flowmaster Super 40
Drop in K&N filter
TJ...RIP
http://www.sajeeps.com/NJ82TJ/
NJ82TJ is offline   Reply With Quote
Unread 06-01-2004, 06:12 AM   #3
Sammy Jenkins
assuming you have stock gears, you would need to get them replaced with the 35's. don't wait until you put the 35's on, do them before hand.
Sammy Jenkins is offline   Reply With Quote
Unread 06-01-2004, 06:39 AM   #4
igofshn
Locked @ both ends
igofshn's Avatar
Without a doubt, you will need new gears.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Unread 06-01-2004, 06:54 AM   #5
tweba99
You will need new gears, you will need to upgrade your rear axle if you have a dana 35 to a super dana or a dana 44, you will also need an SYE and an extended driveshaft.
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote
Unread 06-12-2004, 04:16 PM   #6
booker's01jeep
I have the original gears in it, what gears will I have to get and is it expensive to purchase and install. Also, I found someone who makes custom SYE for around 500. Is it necessary?
