Jeep makes rattling noise.... - JeepForum.com
post #1 of 15 Old 09-21-2004, 06:10 PM Thread Starter
bam9382
I just got a jeep and i noticed that it makes a rattling noise after its been running for a few mins..... the noise only happens when the clutch is disengaged... When i push the clutch in the noise goes away..... The dealership told me this is normal?? But when i take a long trip - 70 miles.... The noise is pretty loud.... when i get where i am going and have stopped....
- Anyone know what this is... and is it suppose to get loud the longer you drive the jeep..... any way to make this go away?
bam9382 is offline
post #2 of 15 Old 09-21-2004, 06:14 PM
mgering
I hate to say this, but it is normal - That can either relieve you or piss you off - it pissed me off at first - but after Chrysler rebuilt my whole tranny, it still did it - it is the slack in the gears - it will not hurt anything. Turn your radio up. - and tell DC to kiss your *** and tighten their tolerances up. No reason that noise should be there.
mgering is offline
post #3 of 15 Old 09-21-2004, 06:20 PM Thread Starter
bam9382
is it suppose to get louder... like pretty loud.. if you drive ur car for a long time????
bam9382 is offline
post #4 of 15 Old 09-21-2004, 06:42 PM
mgering
Mine never got louder. When they replaced my transmission, they told me it had a bad countershaft, yet the noise is still there. If you took a poll on this board, about half would say they have the same noise. If it is extremely loud, by all means have it checked out. - if it sounds like a loose marble, but not real loud, probably the same noise a lot of us have. - There was a bulletin from DC about this, but I think it was 2000 and older models. What year do you have?
mgering is offline
post #5 of 15 Old 09-21-2004, 06:58 PM Thread Starter
bam9382
i have a 2002 does anyone with a 2002 or higher have this noise.... and it only gets louder than normal after a long road trip?? anyone experienced that?
bam9382 is offline
post #6 of 15 Old 09-21-2004, 07:32 PM
battallion14
battallion14's Avatar
I have a 2000 (I know you asked for 2002+) that does the same thing. I took it back to the dealer after I got it and they said it was normal. And having browsed many a Jeep board it appears that is indeed the case. Sounds bad at first, but eventually you will begin to ignore it.
battallion14 is offline
post #7 of 15 Old 09-21-2004, 07:41 PM
rainmn
2014 JK Wrangler
My 2001 does it. No better or worse than my '97 was. You'd think in that kind of timeframe they could have gotten it right?
This is one of my major Jeep pet peeves.
rainmn is offline
post #8 of 15 Old 09-21-2004, 08:45 PM Thread Starter
bam9382
well does anyone have this problem with newer model jeeps.... 02 and up..
and Does anyone notice that it gets louder... after a long time of operation.. like a road trip???
bam9382 is offline
post #9 of 15 Old 09-21-2004, 09:34 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
My 04 does it. I took it in at 1500 miles and they claimed it was "normal"
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #10 of 15 Old 09-22-2004, 12:08 AM
roughwater
I have an 04 that does it, I haven't really paid any attention as to whether it gets louder or not after long trips though. I'm just used to it since I had a 95 that did it as well. If it gets to annoying, I just engage the clutch every once in a while to shut it up.
roughwater is offline
post #11 of 15 Old 09-22-2004, 06:11 AM
Baas
Baas's Avatar
Yip my 2004 Sport does the same thing!! The idiots at Chrysler said it was because I used my vehicle off road and the thrust bearing is wet!!!
My remedy: Get a 4" lift with 33's that will sort out that problem LOL!
Baas is offline
post #12 of 15 Old 08-13-2010, 12:35 AM
Tjpro1990
My 06 is doing the samething. I don't know if I should get it looked at. Did you ever get it looked at and if so what did they say?
Tjpro1990 is offline
post #13 of 15 Old 08-13-2010, 04:10 AM
relgnarw
I ended up changing what gear oil I use, and it got a little quieter. I can't remember what I put in, I think it is Pennzoil Syncromesh(?)
relgnarw is offline
post #14 of 15 Old 08-19-2010, 10:20 PM
Inspect-A-Home
Rattling Noise under jeep
I just bought a jeep wrangler '08 a week ago. it had 37,000 miles on it. It started makin a rattling noise after a week or so, only when gas is applied or on idle. Fortunately I have found where it was coming from. If you look under the jeep, on the exhaust muffler pipe below the tranny, there is a heat shield welded onto the exhaust pipe. with time this heat shield will expand and contract, the spot welds will eventually break! So what I did was just re-weld them and that awful sound was no more...if that doesn't solve the problem you may have to try looking for other areas with spot welds, joints, bushings, etc...hope this helps!
Inspect-A-Home is offline
post #15 of 15 Old 08-20-2010, 12:37 PM
CASnyder1815
i was told that it was the cat. converter that was making the rattling. maybe loose, just wore out. i had a 95 yj 4lit. 6cyl. h.o. all stock and i took it to JEEPSTERS in soddy daisy tn and the mech. was replacin my breaks and i ask him what it was and he said it was the converter and hit it with his hand and it made the vibration/rattling.... Problem solved
CASnyder1815 is offline
stupid noise jeep makes when you have engine on and door open.. WILLY348 TJ Wrangler Technical Forum 10 05-18-2007 08:59 AM
Rattling noise ??? enraged1 TJ Wrangler Technical Forum 3 05-03-2006 08:18 AM
Rattling noise??? TRF TJ Wrangler Technical Forum 3 02-16-2006 12:10 PM
Exhaust rattling Makes me think its Falling apart drunksmurf TJ Wrangler Technical Forum 3 11-25-2005 01:38 PM
rattling noise under jeep NJJeeper YJ Wrangler Technical Forum 18 03-15-2003 03:35 PM
