Jeep lj cb mount - JeepForum.com
post #1 of 18 Old 02-03-2013, 11:17 PM Thread Starter
Ljcrawler05
Jeep lj cb mount
Look guys I've seen a few mounts on JeepForum, and I do believe that the overhead mount is definitely the best for my CB radio. I just can't break myself down to spending a hundred dollars+ on a flat piece of metal. I don't have the resources to do it myself, but was wondering if any of you guys have come up with a clean looking DIY way, that doesn't require drilling that won't break the bank. Thanks
Ljcrawler05 is offline
post #2 of 18 Old 02-04-2013, 01:19 PM
duhamel17
Just installed one in my TJ last weekend. I used a flat piece of aluminum and mounted it to the back of the counsel. I bent the flat plate at a 90 and removed the armrest lid. Once off I drilled holes in the plate and sandwiched it between the arm rest pad and counsel using the existing screws to hold it there. Places the CB verticly on the back of the counsel. Out of the way and almost out of sight for those with sticky fingers. I'll try to post some pics tonight if I get a chance.
duhamel17 is offline
post #3 of 18 Old 02-04-2013, 01:36 PM
LJ-ROD
Plywood and zip ties
It's not death wobble unless you're dead.
Obadiah Build Thread -
http://www.jeepforum.com/forum/f22/2005-lj-obadiah-build-1478051/#post14956502
LJ-ROD is offline
post #4 of 18 Old 02-04-2013, 02:07 PM
tj98
What size is your cb?
My solution required drilling two holes in the change holder on top of the dash. The stock CB bracket was bolted onto it. I'm going to a handheld cb and once I put the rubber pad back in the holes won't show.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #5 of 18 Old 02-04-2013, 02:29 PM Thread Starter
Ljcrawler05
I've got a cobra 29lx with the backlight so a decent size
post #6 of 18 Old 02-04-2013, 02:30 PM Thread Starter
Ljcrawler05
Yeah id like to see a picture of that
post #7 of 18 Old 02-05-2013, 03:38 PM
duhamel17
Here are a few pics of mine mounted to the back of the armrest. Any questions, let me know.
post #8 of 18 Old 02-05-2013, 03:58 PM Thread Starter
Ljcrawler05
I like that better than the overhead mount honestly. I'll see if I can find me a scrap piece of metal and I will probably do it the same way. Thanks for the pics and the idea.
post #9 of 18 Old 02-05-2013, 06:00 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That is how I had my in my CJ. Mine in now under the shifter/drink holder and completely hidden.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #10 of 18 Old 02-05-2013, 11:00 PM
-sean-
-sean-'s Avatar
1944 CJ2
*deleted*
-sean- is offline
post #11 of 18 Old 02-05-2013, 11:03 PM
ctorres018
1930 JK Wrangler
I made one a few weeks ago, cost about 18-20$
Here's my set up
Well it wasn't that difficult at all, I used a 46" steel bar and welded on some small 2"inch tabs to the ends, then drilled holes on the tabs, then on the roll bar, and used 5/16x2.5" bolts with a nut, locking washer, and washer on each bolt. Then put it together. Once i got that i measured the center at about 23" and mounted the cb bracket. And that was pretty much it. Here's a few pics (not great pics)
I guess i didn't really need the tabs because the original plan was to make those tabs an "L" on each end but changed the plan a bit so just stuck with the tabs even though I obviously could of just got a longer bar all across.
Then drilled into the roll bar, I did this because I have door surrounds for the soft top but my dads jeep is hard top and we did the same set up for his and since he has no door surrounds he didn't need to drill a hole he just bolted the bolts into where your door surrounds bolt on top
Bracket on
Once I mounted it on (really ****ty pic sorry )
Finished
And this is on my dads jeep
And that's it. It came out solid so I was happy with it. It's held up pretty good up to now.
ctorres018 is offline
post #12 of 18 Old 02-05-2013, 11:06 PM
sjones26573
You can kinda see mine in this pic. I'm not digging through my 40 pages of Photobucket pics to find the right one.
Velcro on the dash.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #13 of 18 Old 02-06-2013, 12:35 AM
NEI10
Here's my $10 version, post #36:
http://www.jeepforum.com/forum/f20/i...68/index3.html
2013 10th Anniversary Edition Rubicon
Jan/Feb '06 JP Magazine Cover
NEI10 is offline
post #14 of 18 Old 02-06-2013, 12:50 AM
KingofPop
KingofPop's Avatar
Back of the console x10. It is out of the way, easy to run cable to antenna, and I have never had anyone complain about the lack of cupholders in the back.
2005 Silver Wrangler Unlimited
33" Toyo Open Country's, other things.
KingofPop is offline
post #15 of 18 Old 02-06-2013, 07:18 AM Thread Starter
Ljcrawler05
When I get home this weekend I'm going to check clearance between the seats for the huge cobra 29, but I do believe it will fit on the backside of the center console. What I found to be pretty awesome as far as mounting the antenna was the fact that my smittybilt xrc tire carrier bumper has two holes drilled on a flat surface just on the inside of the rear tire so screwing into it or the body is out of play As a side question, since the tire carrier is powdercoated, when the stud goes directly into that hole, will there be a good enough ground for it to operate correctly? If not, will simply scraping some of the powdercoating off take care of it?
