jeep lj broken rear upper shock mount - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > jeep lj broken rear upper shock mount
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-14-2014, 07:33 PM   #1
borja618
Took it to a shop and they ruined the upper nuts just drilled through and put another nut on top of it. So how should I fix this. Would a nutsert work ?
borja618 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 07:40 PM   #2
Jwolfer
Time for an outboard!
Jwolfer is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 07:45 PM   #3
borja618
Need a cheap fix
Unread 08-14-2014, 07:48 PM   #4
J03_TJ
J03_TJ's Avatar
Originally Posted by borja618
Need a cheap fix
Can't think of why what you have now isn't about the cheapest fix there is. Unless it's not fixed.
J03_TJ is online now   Reply With Quote Quick reply to this message
Unread 08-14-2014, 07:50 PM   #5
Jwolfer
Is it working?
Unread 08-14-2014, 07:53 PM   #6
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
sounds fine to me.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 08:36 PM   #7
stwilson74
You already have quick, cost-effective, functional repair and those mounts are notorious for seizing up. If you want, you can take a Dremel with the stylus flexi thing and a tiny cut-off wheel and knock the welds off that hold the factory nuts to the top of the cross-member and then scratch some paint off, tack-weld new nuts on, prime and paint, and then coat the new bolts in anti-seize and re-install your shocks but it won't ride any different.
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
[QUOTE=Necromancer_tat;12078965]I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:[/QUOTE]
stwilson74 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 09:39 PM   #8
borja618
The shop used 4 different bolts rusted already. Looks like they just found some bolts around the shop and bolted them in really disappointed because it is $150 bill and the some inner fender clips and where the put a ratchet to put the nuts on to took the paint down to bare metal so it will rust.
Unread 08-14-2014, 09:40 PM   #9
borja618
Do u all think a nutsert would be strong enough to hold up the bar pin
Unread 08-14-2014, 10:55 PM   #10
Unlimited04
drilling out the crappy stock weldnuts and inserting a longer bolt with a nut on the back is common practice. that's how i had to fix mine.
