The Jeep!!! He Is Dead! D. E. D. Dead! - JeepForum.com
post #1 of 9 Old 02-16-2007, 02:28 PM Thread Starter
ixl4
ixl4's Avatar
2015 JK Wrangler
So the Jeep would occasionally need a battery charge (even though its a new optima)... i figured it was the amp drawing power while the Jeep was off... but now!
I go to start it, its dead. I jump start it, and it seems to run fine. Then I drive it down the street, turn on the lights, and it dies, just plop. dies while its moving. No power whatsoever, none.
None of the dash lights even come on.
When I try to jump start it again, it wont... its as if though the other car isnt providing enough power. The starter barely even turns, its very very lathargic.
I tried 2 vehicles, none could jump my Jeep.
I charged the battery with a battery charger for 3 hours and still none of the dash lights even come on when I turn the key.
Its almost as if though the connections are bad, but I checked, and theyre fine.
Why would it not start when jumping though?
HELP ME!
Thanks.
DR. Z MUST BE STOPPED Club Member # 1
CJC website:
2000 Sport Manual.
Mods: RE 3.5 / JKS 1.25" BL / M.O.R.E. 1" MML / Rough Country Adjustable Trackbar / Dunlop Rover 33s Cragar 397 Soft Wheels / Winch / Nates4x4 Front Bumper & Rear w/ Tire Carrier / RE .75" Spacers / P.O.R.C. SYE / RE CV DS / Nth Degree Adjustable Rear Upper Control Arms / SkyJacker Front and Rear Lower Arms
ixl4 is offline
post #2 of 9 Old 02-16-2007, 02:31 PM
the_ronster
the_ronster's Avatar
check your grounds
RE 3.5 Super Flex, Old Man Emu Long Travel Shocks and Steering Stabalizer, RE Hack & Tap SYE, AA CV Drive Shaft, ARB Compressor, ARB Front and Rear Lockers, 35x12.5x15 Cooper STTs, Custom Fabbed Bumpers, ORFAB rear tire carrier/ gascan holder, Superior 4.88s, and Heated Seats
the_ronster is offline
post #3 of 9 Old 02-16-2007, 03:08 PM
bdhaley
bdhaley's Avatar
I once witnessed the exact problem you were having and a new battery resolved the problem.
1998 TJ, 4 banger, 5 speed, Rusty's 2" lift, 31" BFG At KO's, AR 15x8
2003 KJ Sport 4x4
bdhaley is offline
post #4 of 9 Old 02-16-2007, 03:10 PM
Rocky529
Rocky529's Avatar
As mentioned, check all your grounds and cable connections. You might have a loose one or a corroded one.
Seeing as it died when you were driving, I suspect the alternator also.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 9 Old 02-16-2007, 03:21 PM
Xlr8n
1967 JK Wrangler
Sounds like your battery has one or more bad cells. With a completely dead battery, jumping thru cables often won't give enough juice. Test the battery.
Xlr8n is offline
post #6 of 9 Old 02-16-2007, 03:25 PM
ytodd
ytodd's Avatar
pull the battery and run up to a battery store, get it tested, or try swapping in another to see if it makes any difference....then go from there....
ytodd is offline
post #7 of 9 Old 02-16-2007, 03:39 PM
mike_dippert
mike_dippert's Avatar
i had a 6 month old optima that went bad...advanced auto tested it for me (it was under their warranty). sure enough the battery was bad, so they gave me a new one.
(unfortunately my warranty only covers 1yr from original purchase date, so if this one goes bad after june, I'm SOL)
edit* its a yellow top if that makes a difference
mike_dippert is offline
post #8 of 9 Old 02-16-2007, 03:45 PM
Rule303
Sounds a lot like a bad battery to me! Optimas aren't immune to going bad either. as the poster above said.
I'd double check the grounds coming off the battery though. Check all of them.
Rule303 is offline
post #9 of 9 Old 02-16-2007, 03:52 PM
jm708
2014 JK Wrangler
Check the Battery and the ALt. A lot of places will test them for free.
jm708 is offline
Dead Jeep Sambox YJ Wrangler Technical Forum 26 08-03-2007 09:29 AM
Help jeep is DEAD FLATFENDER54 TJ Wrangler Technical Forum 29 03-08-2007 09:50 AM
The jeep is dead Wheelman TJ Wrangler Technical Forum 2 12-02-2004 12:34 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Wrangler Technical Forum 2 05-01-2004 09:05 PM
help, my jeep is dead Nine5YJ YJ Wrangler Technical Forum 5 08-05-2003 06:02 PM
