Quantcast Jeep hates the winter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep hates the winter
Genuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 12-18-2007, 09:45 AM   #1
Schwalby
I have noticed this over the years with my 5 speed 03 4 cyl that when the cold comes it does not run as well. In past years I have just blown this off because I usually park it for most of the winter. This winter though I have had to use it more and it really sucks. I have found two issues.
1. Shifting into first from a stop can be almost impossible. I usually need to shift into second and then back to first; even then it takes a lot of pressure to get it in. Once the engine has been running for about 20 mins though it does appear to shift better, going between any other gears however is no problem regardless of how long the engine has been running.
2. Not sure if this is related to above or the cold but for some reason my 4wd light will not come on. I am certain it is in 4wd because if I am on packed snow and the rear spins once I pull the lever up to 4HI I am able to move with no spinning. There is also the slight whine from the front shaft. It appears to also come out of 4wd with out any issues as well there has been a few times it does not come right out and after a couple hundred feet I get a little thump and it disengages.
I have a feeling once warmer weather comes I will have no issue again with shifting and maybe the light will start to work again. I just hope the is no large underlying issue here. The Jeep only has about 50,000 miles on it and most of that came in the last year.
Thanks in advance.
Tattoos, women and Jeeps...... I need to find cheaper hobbies.
[QUOTE=Grape Ape] I can act civilized, I know how to act in polite society, [/QUOTE]
[SIZE="5"][URL="http://jeeprally.org/"]Great American Jeep Rally [/URL][/size]
Schwalby is offline   Reply With Quote
Old 12-18-2007, 10:19 AM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
1. Worn synchros (IMO),a good synthetic gear oil might help somewhat(Redline MT-90/Royal purple synchromax).
2. Probably just the 4WD dash light burned out.
TheBoogieman is offline   Reply With Quote
Old 12-18-2007, 10:35 AM   #3
truckin88
switch on top of the transfer case, do a search it is a cheap part there was a post recently about it, same issue with the 4WD light
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know).
RED JEEP CLUB MEMBER #442
truckin88 is offline   Reply With Quote
Old 12-18-2007, 10:41 AM   #4
Beefstew
lol... get it.... avatar!
Beefstew's Avatar
shwalby i feel the same way man... jeep runs awesome in the summer then winter comes and all i wanna do is sell it... rough shift into first.... no heat... bumpier ride....( my light comes on he he) But seriously you know how much it sux to drive something that doesn't defrost... it sux alot!!!
- I should probably look into a good synthetic gear oil...
Beefstew is offline   Reply With Quote
Old 12-18-2007, 10:45 AM   #5
RockRunner85
I have 46k on mine and the 5spd tranny is horrible. Shifting into 1st and from 1st into 2nd either takes a lot of pressure or you can feel the gears bumping when it goes in. Once warmed up it gets better. However I expect more from a 04 transmission.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 12-18-2007, 11:52 AM   #6
MusicMaverick
2010 JK Wrangler
[QUOTE=Beefstew]shwalby i feel the same way man... jeep runs awesome in the summer then winter comes and all i wanna do is sell it...QUOTE]
Yeah, when I lived in the Northeast it was the same. Its fun to take the top and doors off in the summer and have this free flowing feeling. But when its winter, and all you want to do is be warm and comfortable. I would tend to lean toward taking my mom's explorer. Nice, cozy, automatic.
Currently:
2010 Wrangler Sport
Past vehicles:
1992 YJ
1997 TJ
MusicMaverick is offline   Reply With Quote
Old 12-19-2007, 06:46 AM   #7
osudelt69
x2!!!!!!!!!! Have the same issues with 158k miles. Changed manual box to synthetic fluids two weeks ago. Helped a little bit but still can take some pressure to get it into gear. Goes away soon as it warms up.
1997 TJ. 2.5L 161k and counting. Skyjacker hydro shocks. 30x9.5 Dayton Timberline AT. Bestop RAT and Prop Top
osudelt69 is offline   Reply With Quote
Old 12-19-2007, 07:56 AM   #8
MillerTimeTJ
My doesnt like to start when it is cold and definately doesnt shift well until it warms up. i figure i could change out the fluids for synthetic but i drive it like once a week in the winter just to keep the rig from sitting and thats about it.
I definately have the same issues however
97 TJ 4.0 5 Speed 2" Spacer 1.5" BL 33" Trxus MT's
subs, comps. gotta hear it on the highway.
To Do- New Lift, Tube Fenders, D44, 4.56
MillerTimeTJ is offline   Reply With Quote
Old 12-19-2007, 08:55 AM   #9
brooksjeep
for an answer to number 1- in the jeep owners manual, it has a bit of a disclaimer or warning of this. It says that in the winter atleast until your jeep warms up that it will run sluggish, that 1st and 2nd gears will do what yours and mine (mine does it too lol) do. So all u can do is start the jeep early to let the engine get warm, engine block warmer, move south, or deal with it lol
brooksjeep is offline   Reply With Quote
Old 12-19-2007, 10:45 AM   #10
ptowntj
Mine does it too, although I don't think its that bad...it makes sense that it shifts worse in the cold (fluid temp), I generally try to keep my shifts minimal until everything gets warm.
04TJ 3.5 RE Extreme Duty Long Arm, ARB F&R, 4:88's, Cromo shafts, 35 MTRS, Rokmen Armor.
TJ's gone. See you on the trail in my Toyota :).
ptowntj is offline   Reply With Quote
Old 12-19-2007, 10:46 AM   #11
ptowntj
Duplicate Post
Glock Forum
