jeep dont run right - JeepForum.com
post #1 of 9 Old 10-25-2011, 07:07 AM Thread Starter
hotwheels01
jeep dont run right
oil pressure is 0 at idle but when i start drivin t will go up to around 25 or 30 any body kno what that means
hotwheels01 is offline
post #2 of 9 Old 10-25-2011, 07:23 AM
wwch99tj
Could just be the oil pressure sensor bad
Sent from my DROID 2 GLOBAL using Jeep Forum
wwch99tj is offline
post #3 of 9 Old 10-25-2011, 07:54 AM
DKenyon28
DKenyon28's Avatar
I'm sure that you change your oil regularly so this probably won't help you but I thought I'd share. I've seen some people who constantly run their vehicles with the oil being low and showing low pressure. Whenever it is under acceleration the pressure will rise. Like I said this probably isn't the problem but I thought I'd throw it out there.
DKenyon28 is offline
post #4 of 9 Old 10-25-2011, 08:33 AM
Bryon
my Jeep has been like that since day one...(1998,bought it with 75 miles on it)....On low idle/rpms it'd be near zero, rev it up will shoot to 40+.....I change the oil every spring and fall, 64K on it now....I just figured it was the nature of the gauge.
Bryon is offline
post #5 of 9 Old 10-25-2011, 09:04 AM Thread Starter
hotwheels01
mine would stay at 30 but i let it warm up 1 mornin and it did tht so is there any chance i could lock it up blow it up or f*ck it up the oil is full
post #6 of 9 Old 10-25-2011, 09:08 AM
ytowntj
Per FSM the minimum oil pressure at hot idle is 13 psi. Mine is around 25psi at hot idle and 50 under load - with 180k on it.
Does it knock when the pressure drops? Try putting a mechanical gauge on it to verify its not just the sending unit. You should be seeing over 35psi under load, preferably more like 45.
ytowntj is offline
post #7 of 9 Old 10-25-2011, 09:12 AM
ytowntj
What are you trying to conveyconfused:
All vehicle's oil pressure rises in relation to rpm. The oil pump is driven by the distributor or opda depending on year. Both are connected to the cam via gear mesh. In newer vehicles the oil pressure gauge is a dummy gauge and doesnt show true pressure, just high and low.
ytowntj is offline
post #8 of 9 Old 10-25-2011, 09:22 AM
bardb
Mine recently started doing this. Everything was fine at cold startup but the pressure would steadily drop after it warmed up. Ordered a replacement oil pressure sensor from Rock Auto and had it in my hand two days later. Once I figured out how to get the wiring connector off (red part slides btw) it's as easy of a replacement as you could ask for. A little teflon tape to the threads, a shot of carb cleaner in the wiring connector to flush the oil out of it and a dab of dielectric grease to relube the connector and I'm back to 40+ psi.
bardb is offline
post #9 of 9 Old 10-25-2011, 09:57 AM Thread Starter
hotwheels01
how do i install a mechanical gauge
Selling my jeep but dont know what to sell it for.... Zeusismyonlygod TJ Wrangler Technical Forum 18 03-29-2011 09:06 PM
I dont know about these jeep... DunerDude Wrangler General Discussion 3 03-04-2010 04:55 AM
do or dont - take my Jeep to the next level or leave it alone 01TJfuntime TJ Wrangler Technical Forum 14 01-07-2009 03:23 AM
People dont like my jeep at night..... NewhampshireYJ YJ Wrangler Technical Forum 13 12-16-2007 09:59 AM
omg my jeep dont like turning, need help! Warlord2 JK Wrangler Technical Forum 35 08-24-2007 10:38 PM
