jeep does not like puddles??? - JeepForum.com
post #1 of 8 Old 02-10-2009, 01:38 PM Thread Starter
rogernes
got this problem again,if i drive thru slightest puddle , jeep starts to miss fire and you cant rev it out for two or three minetes then it clears and seems ok,it does not give you much hope in this country as it is allways raining?, 1999 2.5 tj,never had this problem with my yj, any help/advice would be appreciated,thanks...........
rogernes is offline
post #2 of 8 Old 02-10-2009, 01:42 PM
SpoonyGSR
make sure your distributer cap is tight
1993 xj 4x4 3" lift, rancho rs 5000 shocks,surco roofrack, cobra 40 ch. cb.,31" savero m/t's roofrack mounted lights(dead)
1994 ZJ 4x4 4.0 3.75 rough country edlebrock shocks 32x11.50r15 bfg a/t's
SpoonyGSR is offline
post #3 of 8 Old 02-10-2009, 01:43 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Check your distributor cap seal. Sounds like there's a wire issue somewhere.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #4 of 8 Old 02-10-2009, 02:01 PM
shotgunsmith
check your dist cap for tightness and cracks. put some dialectric grease on the dist cap contacts and SP contacts. run a bead of silicon on caps mating surface. check that wire have no cracks.
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline
post #5 of 8 Old 02-10-2009, 02:22 PM
rickm8
dont go to wharton
99 TJ Sport 4.0, 5 spd, 2" BB, 31" BFG a/t ko's
BLACK JEEP SOCIETY #362
rickm8 is offline
post #6 of 8 Old 02-10-2009, 02:29 PM
Sobie
Bolt-on Maniac
Sobie's Avatar
start your engine, take a spray bottle of water and start spraying around (distributor, plug wires, also vacume hoses)
Sobie is offline
post #7 of 8 Old 02-10-2009, 02:32 PM
hatfield44
Was your YJ FI or Carb? If you really want to run a lot of the wet stuff, a carb is the only way to go. FI just has more things H20 can screw up.
hatfield44 is offline
post #8 of 8 Old 02-10-2009, 03:55 PM
Stafford
Originally Posted by rickm8 View Post
dont go to wharton
considering he'd have to drive across the atlantic to do it, I think it's a safe bet he won't. Soaked my distributor cap a couple times in the Pines so I do get you point. Water Rd can be a ***** after it rains.
Stafford is offline
water in the jeep after going through puddles?? Dan9 TJ Wrangler Technical Forum 9 08-11-2009 10:55 PM
Puddles in my Jeep dan_yoyo YJ Wrangler Technical Forum 5 07-01-2009 08:58 PM
Puddles on my floor ballallday89 TJ Wrangler Technical Forum 7 06-01-2008 07:42 PM
So I went through some big puddles... 04WranglerX TJ Wrangler Technical Forum 4 11-04-2007 12:26 PM
Bikini Top Puddles... Stiffler YJ Wrangler Technical Forum 22 05-20-2004 09:50 PM
