Jeep does not like getting past 2300-2500 rpms - JeepForum.com
post #1 of 7 Old 06-20-2008, 04:42 PM Thread Starter
Luckyduck
My 2.5 stutters and goes very slow trying to get past 2300-2500 rpms. After that it accelerates like normal (so extremely slowly) It does it more under heavy strain, but can be felt most times.
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #2 of 7 Old 06-21-2008, 08:33 PM Thread Starter
Luckyduck
No ideas??
CentralMass4wd.com
my build
post #3 of 7 Old 06-21-2008, 09:46 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
check your cat. convertor, when mine went bad it did same thing,
RnEmOvr is offline
post #4 of 7 Old 06-22-2008, 08:26 AM
jgorm
jgorm's Avatar
Does it have the same symptoms while free revving it?
jgorm is offline
post #5 of 7 Old 06-22-2008, 08:31 AM Thread Starter
Luckyduck
It is a brand new cat and no I do not believe it does this free reving.
CentralMass4wd.com
my build
post #6 of 7 Old 06-22-2008, 08:45 AM
jgorm
jgorm's Avatar
It sounds like it may be a fueling problem. Have you looked at the plugs yet? This may help to see if its a calibration issue with all cylinders, or if one is worse than the others. Once you figure if its mechanical or electrical you can concentrate you efforts there. Might as well put some new plugs in while your at it. Keep track of what plug came out of what cylinder in case there is a difference in one of them.
jgorm is offline
post #7 of 7 Old 06-22-2008, 08:48 AM Thread Starter
Luckyduck
I put new plugs in in February. I will look at the plugs again and see if there is a difference. I have tried a bunch of stuff and I am thinking cap rotor and wires are next
CentralMass4wd.com
my build
2000 TJ 4.0 Cold Engine Knock Above 2300 RPMS Chief1up TJ Wrangler Technical Forum 1 02-12-2009 10:31 PM
Jeep won't go past 3000 RPMs? please help deathblade556 TJ Wrangler Technical Forum 13 06-22-2007 07:10 PM
problems above 2500 RPMs bradwestmorelan YJ Wrangler Technical Forum 5 12-15-2005 06:48 PM
Stupidity Update: 2300-2500 RPM hesitation Fixed! corst01 YJ Wrangler Technical Forum 0 04-17-2005 08:13 AM
911 -- Help Jeep dying at 2500 RPMs!!! corst01 YJ Wrangler Technical Forum 23 03-19-2005 08:59 AM
