Jeep dies. - JeepForum.com
post #1 of 8 Old 02-05-2007, 11:53 AM Thread Starter
psychoticj
Jeep dies.
This weekend I left my lights on and killed my battery. I jumped started it and it started fine but after it warms up the idle just falls off to 0 and its dead. If i keep my foot on the gas it runs fine now backfires no misses nothing runs as it did before. I can drive down the street fine gets up to speed good. Just when I come to a stop it will die if i dont keep it running. Anyone have an idea this kinda has me lost becuase
i thought if its a fuel filter pump or injector it wouldnt get into the higher rpm range. And ignition problem it wouldn't run good i.e. missing and what not. It seems to like the idle screw would be set wrong if it was a carburator. Is there a jumper i have to hit for the idle to resest maybe TPS is out. Any ideas would help do not want to sit outside in below 0 weather trying to figure this out. Thanks.
edit : it's a 2001 Sport I6 w/ 76000 miles.
psychoticj is offline
post #2 of 8 Old 02-05-2007, 12:03 PM
Xlr8n
1986 TJ Wrangler
Do you have to re-jump start it after it dies? If your battery was completely dead, you'll need to put it on a charger for it to get back to full charge to do it's job.
Xlr8n is offline
post #3 of 8 Old 02-05-2007, 12:06 PM
DR8
DR8's Avatar
Sounds like your running off your alternator... Battery probably has a bad cell? A new battery is most likely the fix but if you can get your battery and charging system checked.
DR8 is offline
post #4 of 8 Old 02-05-2007, 12:08 PM
Blinky
If you have an Auto zone in your area , have them check your battery and alternator (they will do it for free). My guess is that your battery is now probably bad (sulfated cells) it can not put out enough juice to keep the car running at low speed. At higher speed your alternator is putting out the power it needs to keep going, but at low speed it does not. Probably just a bad battery.
2005 Jeep Wrangler Unlimited Impact Orange
1999 Camaro SS
1969 Plymouth Road Runner
1968 Pontiac Firebird HO that needs lots of help
Blinky is offline
post #5 of 8 Old 02-05-2007, 02:16 PM Thread Starter
psychoticj
ok i figure it was something stupid i wasnt thinking about making conclusions to everything else. thanks ill have it checked today after work.
post #6 of 8 Old 02-05-2007, 09:47 PM
Jackle
i've noticed when i kill my battery that when i do manage to get a jump i have to continue to "blip" the gas just to keep her up and running.....this is because the computer has been reset and is trying to learn where the air/fuel ratio needs to be and it is running on a default chart.......if you let it run (help it a little if you need to) for about 10-15 minutes it'll clear itself out......let us know how it turns out
Jackle is offline
post #7 of 8 Old 02-06-2007, 11:37 AM Thread Starter
psychoticj
alright i had my battery checked and altinator just becuase. Both were good. Now it won't die so i learned the idle or whatever and now at a stop it idles at the first mark on the tach under 1000. will it continue to learn till its back were it should be or is it doing that because of the 0 and sub 0 temps? thanks for all the help.
post #8 of 8 Old 02-06-2007, 12:21 PM
SilverTJ998
This happened to me last weekend. After I jumped it I had to keep my foot on the gas. I took it around the block a few times after sitting there for 10min at 1500rpms and it was fine
SilverTJ998 is offline
Got our Jeep wet, Now it dies when we take off. :( srtreat83 TJ Wrangler Technical Forum 12 08-17-2009 11:48 AM
Jeep dies when I turn right ChuckTe TJ Wrangler Technical Forum 12 05-18-2009 11:31 AM
89 Jeep Wr dies when I go to stop Renee30 YJ Wrangler Technical Forum 8 03-13-2009 07:42 PM
Jeep randomly dies.. help.. TorqueWrench87 YJ Wrangler Technical Forum 12 04-28-2008 07:46 PM
Jeep Dies 88mudder YJ Wrangler Technical Forum 5 04-20-2007 01:21 PM
