Jeep Died, no spark, Could be CKP? - JeepForum.com
post #1 of 9 Old 07-04-2010, 08:42 AM Thread Starter
jasonamorris
I posted a post before this asking about the location on the CKP but I thought I would post my entire problem and get some ideas... I have been reading post searches all morning and feel like i'm going in circles...
Yesterday I was enjoying the day when at about 55mph the jeep died completely... I pulled over and gave it a few cranks, it would turn over at first but would immediately die, then nothing...
My first thought was the fuel pump. So when i got it home, I tested the following...
Fuel Pump - i could hear it kick on for 3 or so seconds... Good.
I check for spark and nothing. so the next morning I gave it another try and it fired right up. I let it run for about 15mins and it seemed ok...
I read that if the CKP is bad it will not fire when hot but will work again when cool, is some cases... and my gauges might not work but they is working well...
So I am assuming its the CKP or the cam shaft sensor... Is there an easy way to figure out which of the two it could be??
Any thought??
Thanks,
J
jasonamorris is offline
post #2 of 9 Old 07-04-2010, 08:49 AM Thread Starter
jasonamorris
i pulled the CEL numbers... ??
12,11,54,55
post #3 of 9 Old 07-04-2010, 08:56 AM Thread Starter
jasonamorris
i also would like to add that i had the battery disconnected for a month or so and just installed new battery and terminals, would that cause any issues on the first day running??
post #4 of 9 Old 07-04-2010, 11:39 AM
Outatime05
(Post deleted by author.)
Outatime05 is offline
post #5 of 9 Old 07-04-2010, 06:08 PM Thread Starter
jasonamorris
would the crankshaft sensor be the only thing that allows it to work when cold and not turn over when hot? I'm pretty sure its just the crankshaft sensor but i want to make sure since i'm also getting the 54 code...
post #6 of 9 Old 07-05-2010, 08:52 AM
Outatime05
post #7 of 9 Old 07-05-2010, 09:21 AM
alextremetj
alextremetj's Avatar
A quick test to rule out a crank sensor, while cranking the motor, have someone feel the ASD relay. If you feel it click, then you know the ECM is getting a signal from the crank sensor.
alextremetj is offline
post #8 of 9 Old 07-05-2010, 09:46 AM Thread Starter
jasonamorris
where is the asd relay? sorry...
post #9 of 9 Old 07-05-2010, 12:39 PM
wushaw
Rockin jeep
wushaw's Avatar
Power distrubution box under the hood by the battery.
wushaw is offline
no spark
'92 4.0 just died, no spark not cps garym31 YJ Wrangler Technical Forum 8 02-06-2011 10:55 AM
Motor died, no spark outlaw67 TJ Wrangler Technical Forum 1 01-02-2010 08:37 AM
Jeep died lblair04 YJ Wrangler Technical Forum 6 10-04-2008 07:03 AM
Jeep died on me RockinXJ TJ Wrangler Technical Forum 8 09-19-2006 12:16 PM
97 Jeep died on me.. HELP!!! drew214 TJ Wrangler Technical Forum 16 05-21-2003 04:52 AM
