Jeep death wobble due to tires - JeepForum.com
post #1 of 39 Old 09-23-2012, 08:27 PM Thread Starter
jameskjeep
2015 JK Wrangler
Any help on this as I have no idea what the cause is. So my jeep has the death wobble at 45 MPH any speed over 45 or under 45 is fine. The issue is the tires when I rotate them the issue stops when I rotate them again I have the same issue. So it has to do something with the wear of my tires.
So this happened on my last set of tires. I take it to the jeep dealership tell them about the issue they test my tires and tell me its the tire wear and that I really need to rotate them every oil change and not every other oil change. So I say ok I buy a new set of tires. I rotate them every oil change and now I am having the same issue again. When I got the new tires I did have my jeep alignment and the wheels balanced. But I don't know what the cause could be or what to look for.
I'm running 32 inch BFG mud TA's. What do you guys think?
2005 Black Jeep Wrangler X 6 speed
Python Security System With remote locks
7 Speaker sound system + 2 12" MTX Thunder 6000 Subs
1.25 JKS BL
2.5 OME HD Sup Lift 1 inch JKS MML 32" BFG MUDDS
MT Classic 2 15x8
jameskjeep is offline
post #2 of 39 Old 09-23-2012, 08:56 PM
88hatchy
Tires don't cause death wobble. They can only cause a tire vibration.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #3 of 39 Old 09-23-2012, 09:06 PM Thread Starter
jameskjeep
2015 JK Wrangler
Then it's a very bad tire vibration that causes the jeep to shake like it's going to fall apart at 45MPH. I know its the tires because when I rotate them back it stops. Has to be something with the cause of the wear. I just cant figure out what.
1.25 JKS BL
MT Classic 2 15x8
post #4 of 39 Old 09-23-2012, 09:46 PM
BigRodney
There’s a pretty good article in Fourwheeler magazine, November 2012, about death wobble. I tried to find it online but I couldn’t seem to do it. Page 44. Maybe you’re more competent at searching than I am.
http://www.fourwheeler.com/techarticles/
BigRodney is offline
post #5 of 39 Old 09-23-2012, 09:47 PM
VME
November 2012?
Time travel?
VME is offline
post #6 of 39 Old 09-23-2012, 09:52 PM
BigRodney
Originally Posted by VME View Post
November 2012?
Time travel?
You obviously don’t have a subscription to Penthouse either do you? It’s Christmas in November! ;-)
post #7 of 39 Old 09-23-2012, 10:03 PM
VME
Haha I was jus messing with ya :P
VME is offline
post #8 of 39 Old 09-23-2012, 10:27 PM
ox-yj
Check all your tie-rod ends your track bar for any wear and lower+upper control arms for a any loose bolts.
ox-yj is offline
post #9 of 39 Old 09-23-2012, 10:35 PM
dauster500
1987 YJ Wrangler
get your tires balanced at a place you can watch them do it and make sure the tire balancers screen says "OK OK" before they take the tire off. going to a dealership for things like that theyre just gonna scam you and reach deep into your pocket.
04 5spd 4.0 TJ DD, 87 3spd auto 4.0 yj
Gotmudcnj4x4.org
dauster500 is offline
post #10 of 39 Old 09-24-2012, 05:16 AM
mdm
Farm Wheeler
If the rig has a problem that allows DW, the tires can be the initiator. A shimmy starts because of an out of balance or tread wear problem and loose or worn parts in the suspension and/or steering allows that shimmy to blow up into full DW.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #11 of 39 Old 09-24-2012, 05:34 AM
Jamie_209
Definitely a great idea here. My cherokee with 4.5" lift and 33" tires had the same issue. Turned out to be the track bar bushing was shot. Replaced and fixed the problem.
Jamie_209 is offline
post #12 of 39 Old 09-24-2012, 06:45 AM
Pillswoj
Is it possible you have a bad rim?
Friends don't let Friends run Bosch
Pillswoj is offline
post #13 of 39 Old 09-24-2012, 07:13 AM
Jamie_209
If the wheel is bent that bad it would be felt no matter where it was located. If it was on the rear you would feel vibrations in the seat.
post #14 of 39 Old 09-24-2012, 08:31 AM
lynn
lynn's Avatar
James, read my post here:
http://www.jeepforum.com/forum/f9/in...-lcas-1420526/
I had the shakes at about the same speed as you. Not full-on DW all the time, most often just the steering wheel shakes, clearly a precursor to DW. I did get DW a few times. The shakes and DW were more noticeable when I would rotate tires.
I read hundreds of posts, and paid careful attention to those who knew what they were talking about. I checked my bearings, TREs, track bar/mounts, tire balance, ball joints, all seemed to be OK.
I decided to attack my problem by replacing the front lower control arms. I understood that the factory LCA are marginal at best when new, and I had placed a strain on them with a 3" lift for the last 30K miles. It made sense to me to buy LCAs that would adjust, compensating for the change caused by the lift, yet provide a solid, positive tie-in to the frame.
When I removed my factory LCAs, I slipped the stock bolt back through the sleeve, and I was surprised at the amount of slop between the bolt and the sleeve... yet the sleeve showed little wear or distortion. I could visualize that amount of movement... in each of the four bolts/bushings... and could easily understand the shakes and DW.
If you check all of your other basic steering components and find them all good, you should consider going for the Currie or Savvy JJ control arms...
it worked for my rig.
HTH
Lynn
'05 LJ
lynn is offline
post #15 of 39 Old 09-24-2012, 10:14 AM
tommyduncan
I just put in new upper control arm bushings and was surprised how sloppy the bolts fit through the sleeves. I dropped the rears to see if maybe the wrong hardware was used on the front and they were the same.
tommyduncan is offline
Death wobble after i rotated my tires slikballa TJ Wrangler Technical Forum 23 07-25-2012 11:10 PM
35+ in. tires cause Death Wobble? Mute9937 TJ Wrangler Technical Forum 22 01-05-2011 02:44 PM
Death Wobble Tires surf_frog34 TJ Wrangler Technical Forum 1 05-19-2009 12:54 AM
Lift, Tires, death wobble, help! schu TJ Wrangler Technical Forum 4 04-18-2008 05:13 PM
97 TJ Vibes- Not Death Wobble or Tires deadelvis TJ Wrangler Technical Forum 4 11-03-2005 12:54 AM
