Jeep CKP/CMP sensor problems. - JeepForum.com
post #1 of 10 Old 11-22-2010, 09:34 PM Thread Starter
MiloSC
Recently my jeep began acting up. The engine would begin to shutter while driving, or randomly cut off while I was driving. I replaced the Crankshaft Position Sensor about two years ago, and the symptoms were identicle, so I went out and replaced the senor again. This cleared up the problem for about two weeks. Today I was driving a 150 mile trip, and about an hour and a half into the trip, the engine started doing something really strange. It would start to shutter like before, but only for a brief moment. It eventually shut off on me while I was doing about 70. I got a CEL. I was able to get it restarted and drive it to an exit. I checked the codes, and got 11, 54, and 55.
I can't imagine it woudl be another CPS already. I read on another thread on this forum (http://www.jeepforum.com/forum/f9/ch...sensor-680096/ )that there should be a paper gasket over the crankshaft position sensor. There was no gasket when I replaced the sensor, so it currently has no gasket on it. Would this be causing these kinds of issues?
My other idea is the Camshaft position sensor, but I can't seem to find a replacement for sale.
What do you all think?
Thanks,
Milo
MiloSC is offline
post #2 of 10 Old 11-22-2010, 10:00 PM
Grandpa Jeeper
Grandpa Jeeper's Avatar
When you replaced the CPS did you get it at a parts store or did you get it from a dealer? I have found using OEM with sensors will save a lot of headaches down the road.
The world belongs to those who show up. Get involved!
Grandpa Jeeper is offline
post #3 of 10 Old 11-22-2010, 10:03 PM Thread Starter
MiloSC
I bought the sensor at a parts store. I hope that isn't the issue. I'd hate to have to go drop some more cash on that stupid sensor. Is there any way to test the sensor to see if that is the problem?
MiloSC is offline
post #4 of 10 Old 11-22-2010, 10:40 PM Thread Starter
MiloSC
Also, now that I am thinking about it, the rubber grommet that goes around the CPS wasn't there when I reinstalled the sensor either.
MiloSC is offline
post #5 of 10 Old 11-22-2010, 10:51 PM
Grandpa Jeeper
Spending money on something, just hoping it is a fix is always hard to do. So is walking along the highway in the middle of the night with your thumb in the air. I am just recomending if you do think it is your CPS get an OEM sensor. If you are not in a hurry you can save a few bucks ordering it online.
post #6 of 10 Old 11-22-2010, 10:56 PM Thread Starter
MiloSC
It wasn't a shot in the dark, it was also throwing these same error codes. Thus, this would lead me to the conclusion that it was the CPS. Maybe it wasn't the problem, but it was displaying same symptoms.
MiloSC is offline
post #7 of 10 Old 11-22-2010, 10:59 PM
fishinjeeper
might try cleaning the IAC also...mine did the same thing as yours, it was the IAC and I also thought it was the CPS
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #8 of 10 Old 11-22-2010, 11:04 PM Thread Starter
MiloSC
Yeah, I cleaned the IAC about 10,000 miles back. I have been having problems with the engine rough idling for a long time. It might be time to clean it again.
MiloSC is offline
post #9 of 10 Old 11-29-2010, 09:51 AM Thread Starter
MiloSC
I ordered an OEM sensor to replace the one that is in there. I got the sensor, but it doesn't include the grommet that goes around the sensor. I talked to the guy at the dealer parts department, and he said he couldn't find that in their computer. I also asked him about the little plastic cover that the sensor and grommet fit through into the bell housing, and he said that wasn't in there either. Does anyone know where I might find these parts, or what their part numbers might be?
MiloSC is offline
post #10 of 10 Old 11-29-2010, 08:14 PM
Grandpa Jeeper
The only thing you should have with a new sensor is the paper spacer. You have asked about the grommet several times but as far as I know there is no grommet or plastic cover. Hopefully someone else can chime in and be more helpfull about that.
Anyone have any gas cap sensor problems? Evil_Ed JK Wrangler Technical Forum 21 07-04-2014 10:08 PM
O2 sensor problems Huntinbud TJ Wrangler Technical Forum 7 09-23-2010 08:08 PM
02 sensor problems Wakeboarder06 TJ Wrangler Technical Forum 4 03-03-2008 10:58 PM
O2 Sensor Problems schoena TJ Wrangler Technical Forum 15 02-07-2007 07:46 PM
O2 Sensor Problems?? mattvino TJ Wrangler Technical Forum 1 01-04-2005 06:51 PM
