Jeep buy: 99 with 40K or 03 with 90K? - JeepForum.com
post #1 of 24 Old 12-02-2009, 11:57 AM Thread Starter
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
I've seen a couple dozen TJ's now between 1999 and 2003. Given a similar price of say, $8500 for the TJ's I've been looking at, the choices are older with less miles, or newer with higher miles..
If you were looking for a good start on a DD project, and wanted reliability first and foremost, would you grab a newer model (03 with 90K and showing wear and tear), or a mint 99 with 40K? Were there any substantial design changes in these years?
Doc
The easiest way to find that missing socket wrench is to buy a replacement
2009 Wrangler JK Deep Water Blue 2/door, Auto Soft Top
Automatic/3.73
2.5" RC Coils/1" MORE-BL/3/4" Levellers/Skyjacker Hydros Shocks/JKS 2" Bumps
17" AEV Argent Pintlers/34.4" GY Duratracs
Rugged Ridge XHD Modular Bumpers, locking ends, grill loop
JKS Links/XHD Modular Bumpers/Locking End Units
SB-XCR8 Winch
DocJake is offline
post #2 of 24 Old 12-02-2009, 12:00 PM
champelite210
I'd rather have less miles.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #3 of 24 Old 12-02-2009, 12:05 PM
JeepJeep31
Doc,
I went through the same thing; ended up buying the 99 with lower miles that was in great shape.
There were no sugnificant changes during those years on many of the models; with the exception that I do believe 03 was the year the soft tops were the 4 ply sail cloth (very desirable; wish I had it) but the engine, drive train and suspension are all the same.
OK
-- Oren --
I wave!!!
JeepJeep31 is offline
post #4 of 24 Old 12-02-2009, 12:07 PM
JakeAW
At some point, I believe 03, the spark plugs went to a rail setup rather than a distributor cap, there are other subtle differences as well. Nothing major though.
'98 TJ Emerald Pearl Coat
JakeAW is offline
post #5 of 24 Old 12-02-2009, 12:09 PM
mark02tj
At some point during that time frame the 4.0L went to a distributorless ignition.
Also, the blower motor resistor changed during that time frame, but that's no biggie. Power steering pump changed too?
mark02tj is offline
post #6 of 24 Old 12-02-2009, 12:11 PM
JeepJeep31
Didn't the distributor less engines only happen to the I6?
Thanks mark02tj; your faster than I am
-- Oren --
I wave!!!
post #7 of 24 Old 12-02-2009, 12:12 PM
pmccoy9876
Not sure, but wasn't 03 the first year that they used the NV3500 transmission? Of course, if you want an auto, there's also the issue of the tranny change, but I'm not sure on that. At some point they went from a 3 spd to a 4spd auto (basically, they added an OD gear.)
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
post #8 of 24 Old 12-02-2009, 12:14 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Here's a link from the FAQ you might find helpful:
Changes to the TJ over the model years
Wheelin98TJ is offline
post #9 of 24 Old 12-02-2009, 12:22 PM
1jack5
http://www.jeepforum.com/forum/f9/st...ations-452871/
everything you need to know ^^
if there automatics 97-02 have 3 speeds 03 and up added a 4speed so you have overdrive, i found that out the hard way....
1jack5 is offline
post #10 of 24 Old 12-02-2009, 12:26 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Exhaust manifold and distributorless engine started in 2000'.I've had a 98' 5 speed,2003' auto and 05' 6 speed.A 99' isn't worth $8500 and an 03' is worth much more.I always end up selling mine so I go where the money is.I was offered $13,000 for my 03' with 26,000 miles.I got $10,000 for my 98' (fixed up).If I was going to keep it for a long time,I would go with the lower miles.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #11 of 24 Old 12-02-2009, 12:37 PM Thread Starter
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Thanks guys.. both the 99 and 03 had I-6 engines. The 03 was asking $7999. The 99's asking price is $9000 but from a reputable Honda dealership and will come with 3 month warranty. The 03 had 85K miles, but seemed to need brakes and tires, had a tattered and cracked softop, and a dealer who was as slippery as they get. Wanted an extra $200 just to "prep" it then told me the asking price was "printed wrong" but he would give it to me for what was printed if I bought a warranty which he would use to make any needed repairs. What a scam. I went off on him and walked out. Price was 7999, +200 prep, plus cost of new soft top as the old one was worthless. Either I keep looking or opt for the primo 99 with the 40K.
Automatic/3.73
SB-XCR8 Winch
DocJake is offline
post #12 of 24 Old 12-02-2009, 01:01 PM
rainmn
2014 JK Wrangler
$8K for an '03 is likely to get you a beater, much like you described.
Of the two you described, I wouldn't have to think twice about going for the '99.
(BTW, I recently went through this, and bought a '99)
rainmn is offline
post #13 of 24 Old 12-02-2009, 01:06 PM
mike_dippert
mike_dippert's Avatar
personally i'd look for an '00-'02. Lots of major changes to the 03+.
Main reason for a DD would be the 3spd automatic, and improved engine design. For city driving it just worked better than the 4spd. If you spend a lot of time at 55 or above, the 4spd might be worth it, b/c the OD gives ~25% drop in RPM. But you'd need a LOT of highway miles to make it worth it IMO. and honestly i'd prefer to keep my OD RPM above 2000 (that equates to be about 2750 RPM in 3rd which has a 1:1 ratio). The engine just doesn't have enough power below 2k.
mike_dippert is offline
post #14 of 24 Old 12-02-2009, 01:19 PM
1jack5
i agree w/ dippert, i have a 1999 sport w/ the 3speed and 85,000 miles and it runs great, i had to choose between the one i have now and a 2002 sahara w/ 117,000 miles, so i picked my 99. i am very happy w/ it, i have put it through some pretty nasty stuff and it keeps going and runs great, the only thing i dont like is i dont have over drive for when i have to drive 2 hours back home from school so it cruises at about 3,000rpm at 72ish, but no biggie
1jack5 is offline
post #15 of 24 Old 12-02-2009, 01:47 PM
TheBoogieman
Put some 33's on it and don't regear and it will be perfect.
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 09:31 AM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Got my jeep back from the stealership, update on repairs,fix on jeep rattle>> franco802 TJ Wrangler Technical Forum 5 01-07-2004 06:29 PM
