Jeep Build on a High School Budget - JeepForum.com
post #1 of 5 Old 05-15-2008, 10:44 PM Thread Starter
jaybird02
I bought a 1998 Jeep Wrangler 2.5L with a blown motor, decided to keep the 4 banger for money reasons. I rebuilt it but had it bored .030" over, shaved
.005" off the deck, ported the head and intake manifold, speed pro sealed power engine kit, and cold air intake.
Also I put a 4 in. Rough Country susp. lift with 33x12.5's and stock gears
It runs great! I am very happy with it, the only problem is it now only runs on 89 octane or higher and its my daily driver.
Let me know what you think! Any other ideas?
jaybird02 is offline
post #2 of 5 Old 05-15-2008, 10:57 PM
GOLDJ33P
uhh.. ditch the rc lift =D
jk.. but for way less than the price of the rc lift, you could of gotten about the same thing..
zj v8 coils front, put the front tj coils in the rear (around $50 bucks) new shocks (re monotubes or ome nitrochargers are some of the best for the price $300 but WELL worth it) and a 2''bb (50 bucks).. would give you 4'' of lift.. and ride way better
the coil swap i just said nets a tad bit over 2'' alone.. heck to deal with vibes instead of the 2'' bb and dropping the tc, you could add a 1'' bl with 1'' mml.. this will take place of any vibes up to 3'' (most the time) and you'd have 2'' suspension and 1'' bl..
only reason i say ditch the rc lift is they sag horrible.. rides rougher than ****.. and just arent worth it
i went the cheap route first too because lets face it, im 20 and money at first was limited.. ive only kept the coils (started out with a small 2'' procomp coil/shock lift) i ditched the shocks within the first 100 miles
but for real.. keep the coils since your on a limited budget, get better shocks (trust me you'll want them) and look into a body lift and mml.. you'll only have to add a couple of washers for a tc drop instead of 1'' of tc drop.. and your setup will be good, except most 4'' lift you'll want to run aftermarket control arms
GOLDJ33P is offline
post #3 of 5 Old 05-16-2008, 05:21 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Keep your foot off the gas pedal and the 10 cents difference in gas won't seem so bad.
TheBoogieman is offline
post #4 of 5 Old 05-16-2008, 05:22 PM
4.0l sahara
If you want to run it on regular just get a oversized head gasket to lower the compression back close to stock. Have you calculated the new CR? how far are you above sea level.
4.0l sahara is offline
post #5 of 5 Old 05-21-2008, 08:08 PM Thread Starter
jaybird02
No I haven't calculated the compression ratio, how do you do that? The reason I decided to continue running a higher octane is it ran a lot better than on regular.
Budget Build sshrrt TJ Wrangler Technical Forum 6 07-18-2009 09:15 AM
High School Budget Build Thread BaystateTJ97 TJ Wrangler Technical Forum 30 04-18-2009 11:20 AM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
My budget LCG build? ptwelve TJ Wrangler Technical Forum 13 07-31-2008 11:32 AM
can someone school me on high flow cats? Saba TJ Wrangler Technical Forum 15 01-08-2007 06:40 AM
