jeep broken into - Page 2 - JeepForum.com
post #16 of 25 Old 02-06-2014, 01:11 PM
1shotwonder
Originally Posted by jamie2727 View Post
1shotwonder...Are you referring to the ignition lock cylinder or the car door cylinder. If you mean the ignition lock cylinder, if I buy a replacement, how do I swap out the tumblers to match my current key?
I was referring to the ignition lock cylinder.. Honestly, the best way to explain it would be to watch a video on it.. It's not that hard to swap out tumblers.. Just kinda hard to put into words without confusing the heck outa some people
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #17 of 25 Old 02-06-2014, 01:24 PM
JPGoody
wtroger
I was asking 1 shotwonder how hard it is to replace the tumblers on a new ignition cylinder. But yes to your point I need to see if the casting is broken too. You don't know any info on replacing the tumblers to match my current key do you?
did might help too
http://www.youtube.com/watch?feature...&v=yntb_qGNzEA
JPGoody is offline
post #18 of 25 Old 02-07-2014, 11:15 AM
aeromarknyc
I had the same happen to me 2 weeks ago today. Stealership still has it. should get it back mon or tues after paying $2150(luckily i have comp with 100 deductible). From my understanding, you have no choice but to take it to the dealership to have the SKIS(chipped key) reset. the d-bag that broke into my TJ smashed the ignition and SKIS antenna around the ignition cylinder. It would start and run for about 2 seconds as this what it is intended to do. but once its started without the key...thats it. If someone tells you you can get around it, have them prove it.
http://www.jeepforum.com/forum/f9/th...l-her-2033449/
20140125_114707 (Small).jpg   20140125_114719 (Small).jpg   20140125_114732 (Small).jpg   20140125_120155 (Small).jpg
aeromarknyc is offline
post #19 of 25 Old 02-07-2014, 11:27 AM
bbradUSMC
Not concerned about the door lock so much as the damage to the cylinder. If someone wants to steal it, regardless if the door is open or not, they re still going pop the ignitoin. Looking forward to some constructive help on here....
I believe that was constructive to reduce the extent of future damage done which would reduce the out of pocket expenses for you since you dont have comp coverage.
One of the main reasons I don't lock my doors is because I run a soft top and thieves are notorious for slashing windows for access to the inside. Either way if the door is locked or not someone can enter my jeep. So to save my top I choose to leave my jeep unlocked and dont keep anything in it that I am not willing to loose. Luckily I have the SKIM function, but this wont help much if it gets towed away by a flat bed.
I had my 98 broken into and rifled through when I had it. Since it didnt have the SKIM on it, the very next day I had a security system installed. Sure enough it went off that night. Took me a while to get to it because I lived in an apartment at the time and it was in the parking garage. I think the loud noises and flashing lights scared the thief away because the door was swinging open when I got to it. Probably would have lost my Jeep that night.
Good luck with your repairs.
bbradUSMC is offline
post #20 of 25 Old 02-07-2014, 01:40 PM Thread Starter
jamie2727
aeromarknyc...
They tore apart the skis antenna in mine also. Do you know what they replaced in your jeep? I don't have comp on the jeep, so this all out of pocket expense for me and can not afford a 2100 bill.
jamie2727 is offline
post #21 of 25 Old 02-07-2014, 02:48 PM
aeromarknyc
heres a snapshot of the bill...if you read my post on my situation http://www.jeepforum.com/forum/f9/th...l-her-2033449/ , someone vaguely describes the computer work necessary to reconfigure the SKIM
post #22 of 25 Old 02-07-2014, 03:37 PM Thread Starter
jamie2727
looks like the most expensive parts was the steering column assembly which I read was around 700 bucks, but I saw them used on line for 160.00. So maybe that can save me some big money there. I noticed that I didn't see the ring attenna for the Skis on this bill. I thought you mentioned that it was broken? Do you know if they replaced it?
post #23 of 25 Old 02-07-2014, 03:50 PM
aeromarknyc
i can only assume its part of the "SKIN MODULE" for $135. they better replace it.
post #24 of 25 Old 02-07-2014, 03:54 PM Thread Starter
jamie2727
That makes sense..
post #25 of 25 Old 02-09-2014, 06:31 PM Thread Starter
jamie2727
Originally Posted by wtroger View Post
The big question is did they damage the casting that the cylinder goes in. That is the harder more expensive piece to fix / replace.
Any idea what the part number is for the casting that the lock cylinder slides into? Or at least what its referred to as?
They did break out a bottom piece to it.
