jeep broken into - JeepForum.com
post #1 of 25 Old 02-05-2014, 03:51 PM Thread Starter
jamie2727
jeep broken into
2003 wrangler sport
Just realized my jeep was broken into. The popped the passenger side door with a screw driver I suspect - there s damage to the keyhole. Inside they popped the key cylinder and looks like they broke the collar with the two stubs above and below the where you pit the key in. The key is chipped so they must have been not able to start it and drive away. The key cylinder I found on the floor board. Any idea how what I am going to need to fix this? I don't have comprehensive on it - so it's all out of pocket expense.
jamie2727 is offline
post #2 of 25 Old 02-05-2014, 04:00 PM
JBTJ
Sorry to hear that. Next time don't lock the doors.
JBTJ is offline
post #3 of 25 Old 02-05-2014, 04:02 PM
Gingerkidsrock
I have yet to lock my doors and don't keep anything I don't mind being stolen In the Jeep at all sorry to hear about the break in. Auto part stores can usually get lock cylinders. Maybe quadratec too??
Gingerkidsrock is offline
post #4 of 25 Old 02-05-2014, 04:05 PM Thread Starter
jamie2727
Not concerned about the door lock so much as the damage to the cylinder. If someone wants to steal it, regardless if the door is open or not, they re still going pop the ignitoin. Looking forward to some constructive help on here....
post #5 of 25 Old 02-05-2014, 04:51 PM
number40Fan
2014 JK Wrangler
Get a new lock cylinder and have it keyed to your old key and install.
number40Fan is offline
post #6 of 25 Old 02-05-2014, 05:23 PM Thread Starter
jamie2727
Number 40fan...If I purchase a key cylinder on line, how do I have it keyed to my key? Di I give them my VIN number?
post #7 of 25 Old 02-05-2014, 05:39 PM
goodwrenchdave
Not very clear on the extent of the damage to the ignition cylinder/housing .., picture?
Is the cylinder still there? picture would help.
A locksmith can code your cylinder with an available key.... A dealer does also,, but probably wont want to code your jobber cylinder. You need to find out the extent of the total damage (trim, housing etc) as it may get cheaper to buy a used column and code the cylinder.
The theft vehicles towed in usually end up needing more than just a cylinder as thieves get frustrated and start forcing breaking parts.
goodwrenchdave is offline
post #8 of 25 Old 02-05-2014, 06:04 PM Thread Starter
jamie2727
Here are some pics. It looks like damage was done to it.
post #9 of 25 Old 02-05-2014, 06:12 PM
NotSoMelloYello
You can repin a new lock cylinder yourself. It is not that difficult. I repinned my half doors to match my full doors and ignition so I only have one key. Check youtube for the video how to. Its rather easy. Good luck. If you need help, you could mail me the two cylinder and I will repin it for you lol
NotSoMelloYello is offline
post #10 of 25 Old 02-05-2014, 07:42 PM
1shotwonder
Yup, you're missing a piece on that for sure... I got an extra lock cylinder sitting at home in my garage.. All you'd have to do is swap out the tumblers to match your current key
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #11 of 25 Old 02-05-2014, 07:48 PM
wtroger
The big question is did they damage the casting that the cylinder goes in. That is the harder more expensive piece to fix / replace.
wtroger is offline
post #12 of 25 Old 02-06-2014, 11:39 AM Thread Starter
jamie2727
1shotwonder...Are you referring to the ignition lock cylinder or the car door cylinder. If you mean the ignition lock cylinder, if I buy a replacement, how do I swap out the tumblers to match my current key?
post #13 of 25 Old 02-06-2014, 11:51 AM
wtroger
i am talking about the casting that the ignition lock cylinder goes into. They tend to use either a slide hammer or just a hammer to get the ignition cylinder out usually destroying the cylinder casting
wtroger is offline
post #14 of 25 Old 02-06-2014, 11:59 AM Thread Starter
jamie2727
wtroger
I was asking 1 shotwonder how hard it is to replace the tumblers on a new ignition cylinder. But yes to your point I need to see if the casting is broken too. You don't know any info on replacing the tumblers to match my current key do you?
post #15 of 25 Old 02-06-2014, 12:02 PM
NotSoMelloYello
This video references a door lock but it should be the same for a ignition lock cylinder have to get to the inner part of the lock cylinder to do it
