Jeep brake lights out need help ASAP - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep brake lights out need help ASAP
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!Jeep Grand Cherokee Mirror - Side ViewJeep Grand Cherokee Headlight Assemblies
Unread 06-01-2014, 08:55 PM   #1
lcsballer1
I recently put brake light guards on my 97 tj. I undid the everything to get it on and undid the connector connecting the light. after putting it on I reconnected everything exactly as before. Afterwards my brake lights are extremely dim and when the headlights are on they don't work at all. Also my turn signal now blinks super fast when I hit the brakes. When the headlights are on the turn signals do not work at all. I took it to o reilly auto parts and they took off the light and checked everything and said it looked just fine. The ground wires, bulbs, and fuses seem to be just fine. Please help. Thanks so much in advance
lcsballer1 is offline   Reply With Quote
Unread 06-01-2014, 09:22 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Take the taillights back off and clean the mounting bolt points, add some dielectric grease and try it again... HTH
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread 06-01-2014, 09:24 PM   #3
Rangerz
Rangerz's Avatar
Yep. Bad ground connection.
"Jeeps Love Gas Stations"
Chris - Lost Wages, NV
2002 Dodge Ram 2500 Diesel, 2009 Lance 825, 2005 TJ,
Polaris RZRs.
Rangerz is offline   Reply With Quote
Unread 06-01-2014, 10:06 PM   #4
lcsballer1
So just clean the 3 bolt points and that will fix the problem?
Unread 06-01-2014, 10:10 PM   #5
Mean Max
Don't poke the bear
Mean Max's Avatar
Yup.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-01-2014, 10:22 PM   #6
Knuckelhead
AFSOC Retired
That would be my opinion...
Unread 06-02-2014, 08:23 PM   #7
lcsballer1
Thanks so much guys much appreciated
Unread 06-04-2014, 08:25 AM   #8
ShabanAgayev
Clean the ground connections
ShabanAgayev is offline   Reply With Quote
Unread 06-05-2014, 02:08 AM   #9
Jeep_Porn
Twitter @Jeep_Porn 165k
Yea clean the ground connection... I had the same exact problem and its funny how other people experience the same problem... I love this page!
Jeep_Porn is offline   Reply With Quote
Unread 06-05-2014, 01:17 PM   #10
Knuckelhead
AFSOC Retired
Then why not fill in your profile?...
Unread 06-05-2014, 10:23 PM   #11
geroux
Profile police is needing his quota. This is three threads in a row I've seen this.
geroux is offline   Reply With Quote
Unread 06-06-2014, 04:45 AM   #12
Mean Max
Don't poke the bear
Mean Max's Avatar
So quit reading. Problem solved.
Max
Unread 06-06-2014, 08:27 PM   #13
Knuckelhead
AFSOC Retired
Max
Thanks Max...
Unread 06-06-2014, 10:04 PM   #14
geroux
Thanks Max...
Ya, thanks for the advice Max. I'd just like to open new threads to read without being annoyed by seeing nothing but someone telling someone else to fill out their profile, three times in a row!
Unread 06-06-2014, 10:25 PM   #15
Knuckelhead
AFSOC Retired
And how many time's did it take for you to be told to do that before you got a clue?
