Jeep all over the road - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep all over the road
Genright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!
Unread 01-14-2011, 09:57 PM   #1
fortmacdave
Just picked up a 97 tj , not sure what to think so far, little scarie driving , got pulled over cop thought I was drunk, it looks great and great shape but when you drive down the road its all over the place its like all tires are going to fall off or very loose, I checked all nuts seam to be tight , does not have a lift yet , when you think your going straight then your off to the left then right can some tell me what may be going on.There is some play in the stearing could that be a problem in the stearing gear box?
second no heat or not enought heat , dont seam to be getting a good flow of air coming threw the vents??
Third , its a 2.5 engine but should have a little more pep then it has now , driving up a hill hard third gear , from the bottom going 110klms full tilt but when your half way up be lucky to hit 60klm , tj has 198000 so not bad on mileage, I think its been looked after poorly not abused but just lack of service ,
Any help here would be great , my main consern is why its all over the road from what I can see under all seams to be tight .
Thanks
fortmacdave is offline   Reply With Quote
Unread 01-14-2011, 10:07 PM   #2
baldeagle1
If this is yur first jeep. The short wheel base takes a bit to get used to. I let my girlfriend drive mine and the first few times she was all over the place. Does OK now. Far as the power, if it has bigger tires it may need regearing. good luck
baldeagle1 is offline   Reply With Quote
Unread 01-14-2011, 10:16 PM   #3
kd006
Please fill in your profile, i.e. year, model, engine, trans, tire size, any lifts, mods etc. It would make it much easier to devine the answers.
kd006 is offline   Reply With Quote
Unread 01-14-2011, 10:26 PM   #4
TheStigX
Yeah, I'm all over the road too...I usually can't take my hand off the wheel but only the slightest touch is needed to keep it straight. Test drive another TJ and compare
It didn't seem that deep...
TheStigX is offline   Reply With Quote
Unread 01-14-2011, 10:31 PM   #5
lope
lope's Avatar
Jack up the front end and grab each tire and check for movement/play. If you feel some look to see where the play is. Could be ball joints, tie rods, steering gear, etc. If there's something worn that bad with the steering it could come lose and be dangerous. Because of this you should eliminate steering being the problem first before checking anything else
lope is offline   Reply With Quote
Unread 01-14-2011, 11:11 PM   #6
kylelikewhoa
Check your tire pressure. A tire that is lower on air can cause a pull.
No heat can be a couple things. Make sure you have coolant in the radiator first of all. Jeeps also have a problem with the resistor block for the heater. Mine only had 2 speeds when I bought it with 40,000 miles, the speeds were off and high, it was very annoying.
For the power, it's a 4 cylinder. You could do a tune up and see if it runs any better, and after that maybe do a re-gear. Not a whole lot you can do about the power of the 4 cylinder, except maybe throw a turbo on it.
05' TJ SE (sold)
06' Wrangler LJ
10' JK Islander
kylelikewhoa is offline   Reply With Quote
Unread 01-15-2011, 12:44 AM   #7
kooljp
2005 KJ Liberty
The first thing I would look into would be new tie rod ends. Sounds like yours are pretty bad from what you are saying
kooljp is offline   Reply With Quote
Unread 01-15-2011, 01:16 AM   #8
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Do a front end alignment on it.Set toe-in at 1/8".That will cause the problem too.Check/change the spark plugs,wires.distributor cap and rotor if they're worn for better power.
TheBoogieman is offline   Reply With Quote
Unread 01-15-2011, 01:52 AM   #9
kd006
Query, are castor and camber adjustable also? Have not really looked at my Heep to tell.
Unread 01-15-2011, 01:56 AM   #10
RogueSpear2023
I agree sounds like you tie roads or ball joints are shot, but first I would take it and get an alignment, a good shop will be able to diagnose any worn parts before they do the alignment. As far as no flow good be your blower motor is going out. The 2.5L doesn't have much for power even in stock form, 31s will make a real dent in the power, which can fit on a Jeep with out a lift. I can second the new spark plugs, wires, and distributor cap.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 01-15-2011, 05:04 AM   #11
TheBoogieman
Demonic Jeep Freak!
Nope.You can set the toe yourself in 10 minutes with the help of a buddy to hold the tape measure.
http://www.4x4xplor.com/alignment.html
Unread 01-15-2011, 05:10 AM   #12
gcroswell
Look to make sure the last owner didnt take the sway bar off or leave it disconnected.
gcroswell is offline   Reply With Quote
Unread 01-15-2011, 06:18 AM   #13
fortmacdave
Rear sway bar
Does the 97 tj have or should have a rear swaybar? also there is alot of play in the pitarm going into the steering gear box.
Unread 01-15-2011, 06:19 AM   #14
TheBoogieman
Demonic Jeep Freak!
Some base model (4 cylinder)TJ's came without a rear sway bar from the factory.You really should have one though.You shouldn't be able to move the pitman arm by hand at all.
Unread 01-15-2011, 06:27 AM   #15
grogie
My Rat Bastard
grogie's Avatar
It's not normal to be all over the road. Even at 75 mph with an AntiRock, mine drives straight on the highway with one hand on the wheel.
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
2012 John Deere D140
2013 Junior
Rat Bastard | rat bas-terd |
noun
Of doubtful chronological and geographical grounds; questionable ancestry; mixture of manufactures.
“The only thing that stops a bad guy with a gun is a good guy with a gun.”
grogie is online now   Reply With Quote
