Jeep 2.5l 97 Distributor Pickup to 98+ Distributor Pickup.. Any Differences? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep 2.5l 97 Distributor Pickup to 98+ Distributor Pickup.. Any Differences?
RIGID LED Light Blowout Sale - All Sizes, All Series, all Jeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 07-24-2015, 11:44 AM   #1
Dudman5703
I'm swapping the engine in my 2001 Jeep TJ with a 97 Jeep TJ 2.5l engine.
I noticed on the distributor Pickup, My 2001 engine has flat spade connectors, while the 97 Has round connector pins. Can I just swap these parts over? I imagine it's the same wiring, just different connector..
Thanks!
Parts for reference:
http://www.quadratec.com/products/917241_03.htm '97 Style
http://www.quadratec.com/products/17241_05.htm '01 Style
°llllll° Money well wasted
Dudman5703 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 01:50 PM   #2
Jeepsr4me
Just swap complete dist over to be sure... I know thats what i do... Just make note of exactly where the rotor is pointing in relation to the dist body and remove and replace... Dont have to line up crank or pistons or anything..
I do this all time.... I was going to try and swap out the guts of a dist once, but ran into a issue... it was YEARS ago so i dont remember what it was... But swapping dist takes like a few seconds
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 03:21 PM   #3
Jonny Jeep
Jonny Jeep's Avatar
Connectors and sensors are essentially the same. The 97 connector is a throw back to the YJ which uses the same connector. Just use the newer sensor it'll be fine.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
