Jacking up front end - JeepForum.com
post #1 of 6 Old 02-16-2007, 11:59 AM Thread Starter
NMwrangler
I'm in the process of installing Rubicon front coil springs on my '02 Sport using the write-up from 4x4xplor.com. This is a ridiculously simple question for folks on this forum, but...how do I go about jacking up the front end of my Jeep? Should the jack lift the axle from the differential (which is off-centered), or should I jack the up in the center of the axle shaft? I need to put the Jeep up on Jack stands.
I'm breaking for lunch now, so I'll say my "Thanks!" to all of your replies right now.
2002 Jeep Wrangler Sport
Flame Red, Black Hardtop, Chrome Grill,
4.0L I6, Auto, D35 rear with 3.73 gears,
31x10.5 BFG AT, Rancho RSX shocks, B&M
Trans Cooler, Remote Trans Filter
Previous Jeeps: 1988 YJ Laredo, 1994 YJ
NMwrangler is offline
post #2 of 6 Old 02-16-2007, 12:14 PM
crgrissom
Master of Reality
crgrissom's Avatar
I usually do it by lifting the pumpkin, even though it is off center. Some people have lifted in the center by jacking up the tube, but I never liked that idea. Others jack up one wheel at a time (by the axle) to put jackstands under the frame one side at a time.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #3 of 6 Old 02-16-2007, 12:21 PM
Crashnburn80
Crashnburn80's Avatar
I use the diff as well. I'm sure you know but since your replacing the springs, which is obviously part of the suspension, your not going to want to place the jack stands under the axle, since you will need it to drop in order to get the springs in and out.
Crashnburn80 is offline
post #4 of 6 Old 02-16-2007, 12:28 PM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
you have to put the jacks under the frame to let the front suspension to fully drop down. If you jack up the axle the result is the same as your tires where still on the ground.
[ITA]Tsunami is offline
post #5 of 6 Old 02-16-2007, 12:37 PM
ptowntj
ptowntj's Avatar
I just put it up in the center, right on the axle tube...I think a simple easy lift on it is a lot less abuse than wheeling the rocks. after I get it high enough, I use jackstands on the frame.
8 lug xj.
ptowntj is offline
post #6 of 6 Old 02-16-2007, 12:50 PM
blueknight44
I use the frame to locate 6 ton jack stands, the high clearance of a Jeep permits the use of these tall 6 ton jack stands.
With the Jacks under the frame, one can inspect, work, and service suspended required lube parts
Safety first !!
blueknight44 is offline
jacking up the front of my TJ blackcat471 TJ Wrangler Technical Forum 1 02-18-2009 07:52 PM
Jacking vehicle FritzTJ TJ Wrangler Technical Forum 5 11-07-2007 08:28 AM
Jacking Points jjenkins11 TJ Wrangler Technical Forum 12 05-02-2007 07:43 PM
Jacking Jeep dieseljeep TJ Wrangler Technical Forum 8 10-18-2005 07:49 AM
Jacking up front end b3x TJ Wrangler Technical Forum 3 10-01-2004 08:45 PM
