jack point question - JeepForum.com
post #1 of 5 Old 05-17-2004, 09:39 PM Thread Starter
Sixxcat1
jack point question
Took my Sport in today to get a noise looked at that my clutch was making. A tech came out with a small floor jack and lifted the front of the Jeep so that both front wheels were off the ground about 6 inches. He placed the jack in the center of the axle just left of the differential, like if you were looking at the Jeep from the front. The contact point of the jack to the axle was about a 1 inch circle. Could lifting from this position hurt the axle? I was told to lift from the control arm mounts. I am fairly new to Jeeps and apologize if the question seems ignorant. Thanks for any answers.
01 Z06
03 Tomb Raider Rubicon
07 FJ
Sixxcat1 is offline
post #2 of 5 Old 05-17-2004, 09:41 PM
cajunwrangler
cajunwrangler's Avatar
should be fine lifting from there
cajunwrangler is offline
post #3 of 5 Old 05-18-2004, 07:26 PM
Hal
Hal's Avatar
It shouldn't hurt, I've had my front axle hanging on rocks before and it only scratched the black paint off the axle.
'02 TJ Sport
Hal is offline
post #4 of 5 Old 05-18-2004, 07:48 PM
WeBeJeepin'
WeBeJeepin''s Avatar
just curious as to what kind of noise your clutch was making and what they found out. Mine has been making a clunking sound and can't figure out what it is?
WeBeJeepin' is offline
post #5 of 5 Old 05-19-2004, 12:50 AM Thread Starter
Sixxcat1
Thanks for all the replies. The clutch is just making a squeaking sound when you push it in, but the service writer said it was some type of cylinder on the engine side of the firewall that makes the noise. No clunks though.
01 Z06
07 FJ
Sixxcat1 is offline
5-Point Harness Seat Question KKiowaTJ TJ Wrangler Technical Forum 9 12-10-2007 10:45 AM
4 point harness question Wrangler11 TJ Wrangler Technical Forum 9 07-31-2007 09:52 PM
Differential Housing as a Jack Point? bruker TJ Wrangler Technical Forum 14 07-13-2007 11:12 AM
Engine Jack Point Question 95BadBoy TJ Wrangler Technical Forum 7 06-03-2007 09:36 PM
Preferred "jack" point? Shinner YJ Wrangler Technical Forum 7 08-03-2003 11:37 AM
