-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   It's Official: I have a "one of a kind" Rubi! (http://www.jeepforum.com/forum/f9/its-official-i-have-one-kind-rubi-189261/)
RubiconSS 08-30-2005 04:20 PM
Couldn't find the old thread.
Put on the 2.5" lift - Got vibes.
Tightened everything - vibes.
Put on the rear track bar relo bracket - vibes.
Put on the TC lowering kit - vibes.
Just got all Four (4) tires perfectly balanced - vibes.
Not really sure where to go from here. Will re-check the pinion angle tonite after everybody goes to bed - wife and kids won't speak to me anymore (too much time in the garage).
Nothing has been changed and the rig hasn't seen the woods since the lift.
It's the lift - and it's mocking me.
Sad thing is, I KNEW this was going to happen. :mad:
U.S.MarineLJ 08-30-2005 04:23 PM
That sucks! Sorry to hear that. Perhaps it is time to try a new driveshaft? Wouldn't that help? Hope you get your problem resolved soon at a reasonable cost.
RubiconSS 08-30-2005 04:33 PM
Thanks man. I'm sure it is something "special" about my rig (probably have an unusually heavy glove compartment or something).
What really sucks is: All the experts are telling me it can't be happening, "2.5" lifts (especially w/TC kits) don't vibrate. OK - I'm a retard and the vibes are my "secret friend".
They caught me - imaginary vibes just to get attention.
That calls for MR. :banana:
RnEmOvr 08-30-2005 04:36 PM
axle good and square?? try goin back to stock sounds like theyd get worst :laugh: :brickwall
RubiconSS 08-30-2005 04:40 PM
Not sure if I understood??
Jim Shanks 08-30-2005 04:43 PM
Have some extra wheels/tires you could try, maybe from a buddy's rig? Just thinking out loud. Hope you figure it out. Are they bad vibes?, you're not having death wobble are you? If so, you'd know. That's what's leading me to tires, maybe a separated belt, or bent wheel?
Jim
RockRunner85 08-30-2005 04:46 PM
Pull the rear driveshaft, throw it in 4hi and see if you have vibes. That way you can rule out the rear shaft as the problem.
How bad are the vibes. Does the whole floor vibrate, just the shifter, etc. Is it speed based, rpm based, etc.
Muddeprived 08-30-2005 05:27 PM
Same problem here. Couldn't explain it any better. Everything checks out fine. Drove with front DS and with rear DS and the vibe was still there. DAM# :brickwall
RockRunner85 08-30-2005 05:45 PM
Is the vibe at a constant rpm??. I have that problem since I put on my York OBA with the Kilby brackets. I know this isn't related to a lift kit, but between 1,200 - 1,400 rpm I have a vibe I can feel through teh shifter and slightly through the floor. Everything checks out fine, ,bolts torqued, serptine clutch is good, etc. Not sure where the vibe came from so I know how frusturating it is.
coorsmgood 08-30-2005 05:58 PM
motor mount bad?clutch fan full of mud or bad?or bent?
jeephreak 08-30-2005 05:58 PM
I think its a problem with 05 Rubicons!!! While my SYE pretty much took away all the vibes in the drive line, anything over 60 mph gives me a good shimmy in the steering wheel. Everything is tight, checked and rechecked, tires are balanced (3 times), track bar was checked, control arms, you name it. If you cure yours please let me know what fixed it.
Tenacious 08-30-2005 06:04 PM
SS, I'm in the middle of the same issue. My 04' Rubi has a 3.5" suspension lift and I've done all the things you have, tires are not my issue either. I have a Tom Woods CV rear driveshaft. I have zero degrees on both my pinions, while it sits in the garage. Then, I drive it and have vibes at 60-65mph.
The thing is this. Have someone engage 1st gear and watch your axle twist up as power is applied. That rear axle will rotate under load - a bunch. I just took another measurement on the rear diff-to-pinion and found it to be 4 degrees axle-high. Then I moved it forward and back by hand, and it changed again.
I'm wondering if the natural front/back flexing of my upper control arms could be the cause? This flexing changes the rear driveshaft angles.
I'm using Rubicon Express adjustable uppers - what do you have?
stedwest 08-30-2005 06:20 PM
I have to ask , at what speed do the vibes appear? How many miles on the tires? Have you done a toe adjustment yet?
RubiconSS 08-30-2005 08:48 PM
Toe-in (allignment) was one of my diagnosis steps, sorry forgot that one on my list.
ALL control arms are stock right now.
The vibes are in the floor mostly at speeds (52-54) 65 under load, going up a long hill.
And right before coming to a stop. Wierd, i know.
I am far from giving up. I will get it solved OR expose an undisclosed problem before I'm done.
btolle 08-30-2005 09:13 PM
Before you scream at me (I know you said you had them balanced), I have had lots of problems with tires not being PROPERLY balanced. Interestingly, the problem usually showed up between 52 and 54 MPH and sometimes in the upper 60's (does that sound familiar).
Frankly, I have my doubts that the vibes are caused by the lift since the vibes did not change when you removed each driveshaft.
I know the machine may have said that they were balanced but unless it was one of the new Hunter GSP9700 balancers I doubt they are properly balanced. Believe me I have been down this road and sold a set of TrXus MT's that were probably OK for $40 when they had about 10K miles on them because the dealer could not balance them.
Was disappointed to find that the BFG MT's I bought to replace the TrXus had a vibe at 52-54 MPH. Went back to the tire dealer after 400 miles and they had just received their new GSP9700 balancer. Drove out and had NO vibes at all any more!!
You can find someone with the Hunter by looking at http://www.hunter.com/pub/product/balancer/index.htm
If you don't believe me, go back to the tire store and have them check the balance. After they rebalance (yes they will be out of balance) have them turn the tire 180 degrees on the balancer and they will show up as out of balance.
Bill Tolle
05 Rubicon
04 Liberty
If you love offroading and want the trails to stay open please join Blueribbon Coalition.
"Preserving our natural resources FOR the public instead of FROM the public"
http://sharetrails.org/
The time now is 11:58 PM.
