Quantcast It's ALIVE... mostly that is! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > It's ALIVE... mostly that is!
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 02-03-2008, 05:53 PM   #1
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I just drove the TJ up and down the street with the 32RH automatic transmission that replaced the old 5-speed manual transmission. I'm stoked, it shifts gears fine and no Check Engine light so the locking torque converter must be working ok. It was definitely not a bolt-in job like I expected, even some grinding and welding was required due to the RE longarm skidplate dimensions being set up for a 5-speed, not an automatic.
There's still a lot more little nagging stuff (kickdown cable, new gauges, etc.) to get done including rewiring nearly everything I've added since day one. The auto tranny needed the firewall hole all my add-on wiring passed through so every one of them had to be disco'd. With the new routing they had to take, virtually all of them are now too short so they all have to be either extended or replaced. And with all the 'lectrical gizmos I've installed over the past 11 years, that's a lot of rewiring to be done.
But hey, it DRIVES!
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 02-03-2008, 05:56 PM   #2
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Congrats JB! Have a beer and give your left leg a little rest.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 02-03-2008, 05:57 PM   #3
Schwalby
With out pics it didn't happen
Tattoos, women and Jeeps...... I need to find cheaper hobbies.
[QUOTE=Grape Ape] I can act civilized, I know how to act in polite society, [/QUOTE]
[SIZE="5"][URL="http://jeeprally.org/"]Great American Jeep Rally [/URL][/size]
Schwalby is offline   Reply With Quote
Old 02-03-2008, 05:59 PM   #4
elkfan2
elkfan2's Avatar
Sounds like it was a good experience.
elkfan2 is offline   Reply With Quote
Old 02-03-2008, 06:01 PM   #5
Jerry Bransford
Mostly.
Getting Savvy...
Old 02-03-2008, 09:20 PM   #6
bustedtj
any pics of the process
2000 sport 4.0 .... stuff (0lllllll0)
Originally Posted by Contra View Post
but my most hated thing on a jeep is the decal that says "flip me over if you can read this" on the windshield
bustedtj is offline   Reply With Quote
Old 02-03-2008, 09:40 PM   #7
95BadBoy
Jerry, congrats on the trans project. Welcome to the dark side..... er , no - the fluid drive side.
95BadBoy is offline   Reply With Quote
Old 02-03-2008, 09:54 PM   #8
elkfan2
elkfan2's Avatar
I'd be curious to know your likes and dislikes now after the swap and a few runs because I have kind of contemplated the same but there is a lot I like about my manual though.
Old 02-03-2008, 10:08 PM   #9
cb19950
i wanna know about rpms cuz im about to be running that?
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline   Reply With Quote
Old 02-03-2008, 10:10 PM   #10
AlTheKillerr
that would be the three speed right?
AlTheKillerr is online now   Reply With Quote
Old 02-03-2008, 10:23 PM   #11
Jerry Bransford
Yep the venerable 3-speed 32RH.
Here's a few photos...
#1 Just got the shifter out, that's a gaping hole for sure.
#2 That's the old 5-speed tranny and t-case coming out
#3 Grinding the welds off the skid plate, I had to move the tranny mount forward 5"
#4 Gunnys TJ (Joe) mounting the new deep ATF pickup
#5 Gunnys TJ getting the shifter installed and working
I have to really thank Joe for his help, 3 days worth!
Still have to wire in the tranny temperature gauge, install the kick-down cable (for passing gear), and reinstall all the wiring that had to be torn out, plus a whole bunch of other stuff. A fuel filter is going in too.
At least it's driveable, though it's not ready for the trail yet.
Hmmmm.... not sure why the pics are not click-free, must be the new board software acting up.
Getting Savvy...
Old 02-03-2008, 10:27 PM   #12
UTWeezul
Looks nice!!! Hope you like it and get everything buttoned up on it so you can see how it does on the trails!
Edit: Any problems with the deep trans pan and your high clearance skid plate? I'm about to do a tummy tuck on the TJ and just put on the deep trans pan.
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Old 02-03-2008, 10:39 PM   #13
Zoom By You
Well, it must have been something you always wanted, now you have it, it was worth the effort. Don't accidentally slam on the brake thinking it's a clutch....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline   Reply With Quote
Old 02-03-2008, 10:45 PM   #14
Jerry Bransford
No, there is plenty of clearance for the pan itself. If you install a tranny temp sender bung, make sure to mount it on the 45 degree side as below on the left. It's too close to the driveshaft on the flat side nearest the driveshaft where mine is so I had to install the sender into a T-fitting, below, so it doesn't stick straight out.
Getting Savvy...
Old 02-03-2008, 11:08 PM   #15
dae03TJ
wel done jb
When in doubt, just gas it!!!
dae03TJ is offline   Reply With Quote
Glock Forum
