IPF 968's... factory wiring or kit supplied wiring?
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series |
#1 | |
I'm a wiring NOOB and a half... and ready to replace my existing stock fogs with these IPF 968's:
I'm just wondering if I can unplug my wiring from my stockers and simply plug it into the 968's? IS this doable or do I have to use the wiring supplied in the kit??? They are both 55W.
Visit My Homepage! |
#2 |
You could probably get away with it, but........Look at the size of the wires, are the ones from the IPF's bigger?If so, its likely they will be a better option than the factory.
These are a very good quality set of lights, I would recomend you install the entire kit, as the MFG intended. Its not that hard and its a good time to learn. Leave your self plenty of time, roll up them sleaves and have at it!! Good Luck, CW
'99 TJ 4.0 5 spd D30 W/AUSSIE & 8.8 W/ECTED 4:10's http://cave76.org/forums/cromag.php?mode=viewcromag&u=cwlongshot '89 MJ 4.0 AW4 Hi-Pinion D30 with SPARTAN D44 W/DETROIT LOCKER 4:56's http://comancheclub.com/forums/viewtopic.php?t=1230 |
#3 |
mmm yeah you're right, I should set it up as the manufacturer intended. The tricky part is this... I want to set them up so that they work exactly as my stockers do now. I want to use my factory switch that's on the light stalk, not the kit supplied button switch. That way I don't have an extra switch on my dash that I don't need. I wonder how difficult that will be
#4 |
Not a big deal. You should be able to do that.
Hopefully someone will pipe in and tell you what wire does what. (I dont have factory lights) It should be a three wire plug, in out and ground. Remove the factory wire plug and using crimp connectors, wire in the new wires. All the switch does is break the connection. Do a little trace for yourself, follow the wires as far as you can to see where they go. Most likely one goes to ground somewhere close to the switch. Make up a replacement wire that will do the same. Then use the other two inplace of where the MFG's supplied diagrams show. CW
'99 TJ 4.0 5 spd D30 W/AUSSIE & 8.8 W/ECTED 4:10's http://cave76.org/forums/cromag.php?mode=viewcromag&u=cwlongshot '89 MJ 4.0 AW4 Hi-Pinion D30 with SPARTAN D44 W/DETROIT LOCKER 4:56's http://comancheclub.com/forums/viewtopic.php?t=1230 Last edited by cwlongshot; 01-31-2005 at 10:07 PM.. Reason: kant spel goud |
#5 |
plug up the IPF relay as stated in the directions. Just hook the trigger wire(yellow) to the output signal wire for the factory fog lights.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
