Inverted T steering hitting front diff cover! - JeepForum.com
post #1 of 12 Old 05-30-2009, 10:14 AM Thread Starter
yippieayae
Hello all. My name is Carlos and I am new to the community. I am writing because I have a question. I have (just yesterday) installed a Rugged Ridge inverted T steering on my '04 Rubicon. The jeep is lifted 4.5 inches and I am running 33's on 3.5: of backspacing. My clearance issues are between the steering tie rod and the differential cover. It is the stock cover. Has anyone else experienced the tie rod coming into contact with the diff cover on this type of setup??? Any help at all would be greatly appreciated! Thanks!
yippieayae is offline
post #2 of 12 Old 05-30-2009, 10:28 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm no fan of inverted T steering in any brand, but a small bit of contact with the diff cover will not hurt anything in the slightest. If you think about how much time you spend with your tires at full lock either direction, it's pretty much a non issue.
The only time it becomes an issue is if the contact stops you from turning the wheels fully one way or the other and even then, it takes a very stout tie rod to prevent that from happening. Every tie rod I've ever seen will bow first when it hits the cover.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 12 Old 05-31-2009, 12:40 PM Thread Starter
yippieayae
Thank you for the input!! I should share that the majority of my technical training comes from the U.S.A.F. I am an old school crew chief and any time I see ANYTHING that doesn't look 100% rock steady, I start to question it. After slapping a fresh coat of rattle can paint on it and carefully running my steering from full lock to full lock, it seems that the tie rod is just barely making contact with the diff cover at full left turn. The fresh (and still soft) paint wasn't scratched off. This leads me to surmise that the contact against the diff cover is just enough to irritate me and not enough to bend, break my diff cover or cause any serious internal ring/pinion damage. I like to look at things in terms of "worst case scenario". I took her out for a test drive around the block and down the country roads. Got her up to 60 mph without the steering stabilizer installed. It is handling very well actually. I did not notice a dead spot at all. Of course, this is the first time it's been driven with the new steering. We'll see how she behaves once the TRE's break in a little. My perfectionism might still get the best of me causing me to custom fabricate a driver side TRE with a 10 degree bend in it to keep the tie rod off the diff. Whaddya'll think???
post #4 of 12 Old 05-31-2009, 01:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Can you adjust the steering stop just a bit to avoid contact?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 12 Old 05-31-2009, 02:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Take a ball peen hammer and dent the skid in slightly where the paint mark is. You have plenty of room and it won't hurt a thing. That will satisfy the Air Force training you have and work perfectly.
I am Savvy
mrblaine is offline
post #6 of 12 Old 05-31-2009, 02:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
As long as it's not a "cast" part!
Max
Mean Max is offline
post #7 of 12 Old 06-01-2009, 12:05 AM Thread Starter
yippieayae
Max
I thought about that, and that might actually be what happens. Of course, now I am looking at all sorts of high steering knuckles for my axle, but since I don't have hordes and hordes of cash for disposal right now, it looks like breaking a tack weld and re-tacking a bolt a couple of threads out might be the more economical way to go! The true test will be when we get her offroad, disconnect the sway bar and let the axle droop down to full flex. This jeep is not by any means going to be a super-delux monster 4x4 anytime soon, so as long as I can safely and reliably drive her up some class 3 and maybe 4 trails and on city streets, I'm a happy wheeler! I'll post up the final approach I take as soon as it's ops checked! Thanks to all for the posts and please keep 'em comin'! Always looking for good info and always learning!
post #8 of 12 Old 04-17-2011, 06:24 PM Thread Starter
yippieayae
Updating the situation: I purchased and ARB Dana 44 front diff cover and I have washered the tie rod ends to almost completely eliminate the roll factor. The diff cover is a very close fitting cover and it provides me with a ton of clearance. Also, she's been wheeled quite a bit since the original post. Both the diff cover and the steering rods have been in 'gentle' contact with rocks that were anchored to the center of the Earth and neither has failed.
post #9 of 12 Old 04-17-2011, 06:49 PM
epeck87
yippieayae in your first post you said you have a stock diff cover but in your specs you have a front ARB diff cover listed. update your information to make it easier for people to help you. if you had the arb cover you should not try to bend it in hitting it with a hammer. a few hits with a hammer like blaine suggested should work fine with the stock stamped steel cover. dont hit it in any farther than you have to.
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
post #10 of 12 Old 04-17-2011, 06:59 PM Thread Starter
yippieayae
Profile updated.
post #11 of 12 Old 04-17-2011, 07:03 PM
epeck87
Profile updated.
well now im gonna sound like an anal ******* but you spelled rubicon wrong in your specs also. not that i really care but i just thought id let you know.
welcome to the forum
epeck87 is offline
post #12 of 12 Old 04-17-2011, 07:09 PM Thread Starter
yippieayae
Profile update updated. However, I did spell Jagermeister correctly on my shopping list...
Front Diff./Diff. Cover Mating Surface munroejp TJ Wrangler Technical Forum 4 12-12-2009 01:03 PM
JKS adj trackbar hitting DANA 30 diff cover ! jeep2008 TJ Wrangler Technical Forum 36 02-25-2009 07:49 AM
OX Diff cover work with steering upgrade? Idaho-Jeep TJ Wrangler Technical Forum 8 06-24-2008 07:40 PM
WTF! Took all the bolts out of diff cover...tried hitting it, spitting at it, and... JeepinYahoo TJ Wrangler Technical Forum 6 07-23-2006 08:02 PM
Diff cover hitting gas tank skid UCTJ TJ Wrangler Technical Forum 7 08-21-2005 10:04 PM
