Intermittent beeping on startup - JeepForum.com
post #1 of 5 Old 07-28-2010, 09:53 AM Thread Starter
moitura
moitura's Avatar
When I go to start my Jeep, usually I put the key in the ignition and half-turn it for a second or two (the Jeep beeps at me and some dash lights come on at this point), then I turn the key enough to engage the starter and start the Jeep.
Recently, when I put the key in the ignition and half-turn it, sometimes the Jeep no longer beeps at me, but will start just fine. It is an intermittent problem, sometimes it beeps at me, sometimes it doesn't. It isn't a major issue as the Jeep is starting up just fine, I'm just curious if something is going out? Has anyone has seen this issue before?
moitura is offline
post #2 of 5 Old 07-28-2010, 03:29 PM
wushaw
Rockin jeep
wushaw's Avatar
Your beeper is dying a slow death, you can either be thankfull or you can fix it.
wushaw is offline
post #3 of 5 Old 07-29-2010, 11:46 AM
Jonny Jeep
Jonny Jeep's Avatar
It might be the switch in the seat belt clip that is dying. The initial beeps when the ignition is first turned on is a seat belt reminder chime. Or are you fastening your seat belt sometimes before starting up? That will stop the chimes sounding.
Jonny Jeep is offline
post #4 of 5 Old 07-29-2010, 12:02 PM Thread Starter
moitura
moitura's Avatar
Haha, yeah that was the first thing I thought I was doing, but turns out it doesn't beep sometimes without the seat belt fastened.
moitura is offline
post #5 of 5 Old 07-30-2010, 02:25 PM
Jonny Jeep
Jonny Jeep's Avatar
If it doesn't beep when the seat belt is unfastened it must be the seat belt switch then. The switch is normally connected to ground and when the belt is clipped in the switch opens breaking the circuit. If the contacts have gone bad it must be getting a connection just part of the time.
beep , start , key , ignition , tj , wrangler
06 tj started beeping at me yellowismellow TJ Wrangler Technical Forum 5 10-10-2007 09:10 PM
random beeping? 03Wrangler TJ Wrangler Technical Forum 7 08-21-2007 09:04 AM
Beeping at any speed STUCKINMUD TJ Wrangler Technical Forum 7 08-04-2007 11:33 PM
Random Beeping WranglerX22 TJ Wrangler Technical Forum 7 02-21-2007 01:47 PM
What is that beeping sound? Ned97sahara TJ Wrangler Technical Forum 10 06-02-2003 07:36 PM
